little help on JDMb16a specifications
Old Oct 19, 2004 | 09:42 PM
JDMb16ef's Avatar
Default little help on JDMb16a specifications
hi, i am replacing my timing belt and my water pomp and my thermostat from my JDMb16a, so i was wondering how could i order this parts?
One more thing which tranny is better the Ls or the B16, cause my friend has a JDMb16a with a ls tranny and it feels pretty good, i am asking this because my tranny is getting really bad and i donno what to buy so i llitle of help would be good
Thanks
Old Oct 19, 2004 | 10:26 PM
mrspeaker's Avatar
Default Re: little help on JDMb16a specifications (JDMb16ef)
B16 trannys have better acceleration and gearing for the motor then the LS..
LS tranny would be a major downgrade..
Whats wrong with the tranny ..its it grinding??
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
Bitch Pin Shift Linkage 91 crx si ???
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets (8) 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
Old Oct 20, 2004 | 07:19 AM
JDMb16ef's Avatar
Default Re: little help on JDMb16a specifications (Mrspeaker)
yes it is the grinding and the third is out .Thanks a lot
Old Oct 20, 2004 | 08:32 AM
StupidSlowRSX's Avatar
thats a nice write up of b16 part #'s and interchangable parts... and for the record a crx si shift linkage wont work with a b16.. its about 3" to long. You can either cut the amount needed off your stock linkage ( which is what I did.. works great) or order a hasport/avid racing
Old Oct 20, 2004 | 08:35 AM
EL Vap133's Avatar
Reaplce your tranny fluid with some GM syncromesh.
Old Oct 20, 2004 | 09:51 AM
teler86's Avatar
Great Specs on the parts, I really needed those too, how did u find them?
flaxx0r
Feb 28, 2009 06:18 PM
Origin
Nov 3, 2003 07:56 AM
90hbvtec
Oct 31, 2003 10:08 AM
conceptEG
Sep 4, 2003 10:44 AM
Monty
Sep 7, 2002 05:41 AM
