custom cluster question
i am considering fabricating a custom gauge cluster for my 91 si civic. i would like to use an autometer speedo, tach, temp, oil pressure and fuel gauge. i would cut a plastic bezel and mount the guages behind a piece of lexan in the stock location. my question regards the connection of the speedo and fuel gauges..... i would like to use the factory harness and just attach the aftermarket gauges to the wires i already have. i know this would work for tach and temp but i am unsure about the speedo and fuel..... any help would be great. thanks--dave
if you can somehow adapt the stock speedo cable to work an aftermarket gauge you'll be able to pull it off.
If not, install a VSS from a 92+ Civic and then use the sender wires for the signal for a speedometer.
so the eg vss is electronic right? what kind of connection would i have to have to make the speedo work? im sure somebody knows...........but thanks for your input--dave
the only one i can find is the autometer.....its so damn expensive tho. especially if i get the other gauges too. doen anyone know of any other options? if so i would want one that would be less expensive......thanks--dave
2TrippleOhSi
Jun 8, 2011 10:02 AM
