Honda S2000 Honda S2000
What the heck is an A.I.R. Pump on an S2K?
Old Oct 19, 2004 | 06:20 PM
AKS2K's Avatar
Default What the heck is an A.I.R. Pump on an S2K?
I slid my s2k down an embankment and knocked the "AIR" pump loose which, according to my dealership, caused my check engine light to come on. Can anyone give me some insight into whether i need this part. Do you get rid of it when you get an aftermarket exhaust system?
Old Oct 19, 2004 | 07:33 PM
Ahhvtec1's Avatar
Default Re: What the heck is an A.I.R. Pump on an S2K? (AKS2K)
That unit is in front of your driver's fron tire. If you remove your bumper, you will see it imediately. Will you need to remove it to replace your exhaust? nope.
Duc
Old Oct 19, 2004 | 09:09 PM
AKS2K's Avatar
Default Re: What the heck is an A.I.R. Pump on an S2K? (Ahhvtec1)
The dealership said it's burnt out and that i need to replace the air pump. how difficult and expensive should that be?
Old Oct 19, 2004 | 10:06 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AKS2K &raquo;</TD></TR><TR><TD CLASS="quote">The dealership said it's burnt out and that i need to replace the air pump. how difficult and expensive should that be?</TD></TR></TABLE>
Not difficult but if you are not mechanically inclined, have them do it. The pump forces cold dense air into the exhuast system to heat up the cat converter quickly to reduce cold start emissions.
On a rant: I believe that secondary air injection system (fancy name for the pump and setup) causes secondary combustion in the cat converter that damages the o2 sensor in the cat. Mine was broken throwing a check engine light a few years ago, several others complained about the same problem.
Old Oct 20, 2004 | 03:57 PM
Ahhvtec1's Avatar
Default Re: What the heck is an A.I.R. Pump on an S2K? (vapor)
Vapors you have a wealth of knowledge!
Old Oct 21, 2004 | 06:44 AM
vtecvoodoo's Avatar
Future Texas Boy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">
On a rant: I believe that secondary air injection system (fancy name for the pump and setup) causes secondary combustion in the cat converter that damages the o2 sensor in the cat. Mine was broken throwing a check engine light a few years ago, several others complained about the same problem. </TD></TR></TABLE>
Happened to me, too.
Old Oct 21, 2004 | 07:23 AM
Ekasey's Avatar
Default Re: What the heck is an A.I.R. Pump on an S2K? (vtecvoodoo)
To Elaborate a little furhter on vapors rant
The secondary air injection system is only used for 15 seconds during initial start up of the car this helps as said heat the cat by burning oxygen.
The secondady air injection pump looks like a little round black canister. Only reason it's there is to help Honda comply with LEV standards on a finely tuned vehicle!
Don't quote me on this but that AIR injection pump on the s2k's look like factory BMW's try and fine one from a BMW junkyard i will check jack's car this morning
Old Oct 21, 2004 | 11:27 AM
SpeedXRacer's Avatar
Thats why you hear a initial whistle when you start your car which quickly goes away.. sounds like a small BOV heh.
Old Oct 21, 2004 | 03:44 PM
USDMforLife's Avatar
Default Re: (SpeedXRacer)
any input on modifying it so it pull crankcase pressure for boosted applications...
Old Oct 21, 2004 | 03:59 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ahhvtec1 &raquo;</TD></TR><TR><TD CLASS="quote">Vapors you have a wealth of knowledge!</TD></TR></TABLE>thanks buddy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">
Don't quote me on this but that AIR injection pump on the s2k's look like factory BMW's try and fine one from a BMW junkyard i will check jack's car this morning</TD></TR></TABLE>
I wouldn't be surprised if it was similar but the connections will be different and possibly the pump will be different as there are more cats in a BMW than the s2000.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMforLife &raquo;</TD></TR><TR><TD CLASS="quote">any input on modifying it so it pull crankcase pressure for boosted applications...</TD></TR></TABLE>
I would pic a vacumn pump that uses less current/draw than the secondary air injection pump, if you've seen the wiring on that sucker, you'll see it eats up some serious juice.
Old Oct 21, 2004 | 04:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">I would pic a vacumn pump that uses less current/draw than the secondary air injection pump, if you've seen the wiring on that sucker, you'll see it eats up some serious juice. </TD></TR></TABLE>
I'll have to look into it more and actually get some info on the pump. I'd rather use the pump that I have since I already have it, and it's there.
Old Oct 21, 2004 | 04:07 PM
evil vapor's Avatar
Default Re: What the heck is an A.I.R. Pump on an S2K? (USDMforLife)
I'll have to look into it more and actually get some info on the pump. I'd rather use the pump that I have since I already have it, and it's there.</TD></TR></TABLE>
I know since you have it already, you'd like to make use of it, but honestly, there are already crankcase vacumn pump kits out there for a few hundered bucks.
Old Oct 21, 2004 | 04:19 PM
I know since you have it already, you'd like to make use of it, but honestly, there are already crankcase vacuum pump kits out there for a few hundered bucks.</TD></TR></TABLE>
Yeah I know... But I have other priorities which I would rather spend the $300.00 on. So who know, I still have to look into how much power it drawls and how much vaccum it can pull to see if its actually worth the effort. Hey and if everything looks good than it'll be a nice DIY project
Old Oct 22, 2004 | 12:10 PM
evil vapor's Avatar
Yeah I know... But I have other priorities which I would rather spend the $300.00 on. So who know, I still have to look into how much power it drawls and how much vaccum it can pull to see if its actually worth the effort. Hey and if everything looks good than it'll be a nice DIY project </TD></TR></TABLE>
Old Oct 23, 2004 | 09:22 PM
AKS2K's Avatar
Hey Vapor, thanks for the info. The dealership wants $850 for the AIR pump. I think their smoking crack. What do you recommend?
Old Nov 8, 2004 | 12:32 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AKS2K &raquo;</TD></TR><TR><TD CLASS="quote">Hey Vapor, thanks for the info. The dealership wants $850 for the AIR pump. I think their smoking crack. What do you recommend? </TD></TR></TABLE>
have you tried looking on online honda parts sites? http://www.hondautomotiveparts.com etc etc etc?
Old Nov 8, 2004 | 07:59 PM
GradyDC5's Avatar
OHHH!!! I wondered what that sound was. I love this board.
Old Nov 9, 2004 | 01:26 AM
poop32145432's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">have you tried looking on online honda parts sites? http://www.hondautomotiveparts.com etc etc etc?</TD></TR></TABLE>
Sorry, to burst your bubble Vapor but its:
http://www.hondaautomotiveparts.com
"Majestic Honda" Great for OEM parts, fast delivery, and excellent prices.
Old Nov 9, 2004 | 10:14 PM
baonest's Avatar
Default Re: What the heck is an A.I.R. Pump on an S2K? (mp7235)
it could possibly just be a burnt out fuse.....
check for that...
the air pump is not cheap.........
TopEndTuner
Honda S2000
Oct 11, 2012 12:51 PM
JUSTINTHECOASTI
Honda S2000
30
Oct 24, 2011 12:56 PM
ma_rio44
Honda S2000
Nov 5, 2008 06:32 PM
MADBADGER
Honda S2000
10
Jun 27, 2008 04:57 PM
shift6th
Honda S2000
Mar 30, 2004 12:30 AM
