HELP...anyone swap a obd1 motor into your obd2 car?
alright, i got a gsr that i am going to be swaping into my civic. the gsr is obdI and my car is obdII. the thing is i have 2 ecu's that i can use. i have a obdII ecu from a si and a obdI ecu. If I want to use my obdII ecu do i need to get a obdII distributor? And if i want to use the obdI ecu will i only need a harness?
I was wondering what you guys did??Thanks...
yeah obd I you can use the harness, obd 2 you will have the crank position sensor which is at the bottom of the timiing cover, where as obd1 that sensor is built into the distributor
inline4
15
Sep 9, 2003 03:03 PM
