Question about the Purge Control Solenoid Valve
Old Oct 19, 2004 | 04:45 PM
1999gs-r's Avatar
Default Question about the Purge Control Solenoid Valve
It seams to be making a ticking noise and the car is running rough. When I unplug it the ticking goes away and the idle goes down a bit. Does this mean the the valve is bad? Any help would be great. Thanks in advance!
Old Oct 20, 2004 | 02:25 AM
1999gs-r's Avatar
Default Re: Question about the Purge Control Solenoid Valve (1999gs-r)
Anyone?
Old Oct 20, 2004 | 06:25 AM
JimBlake's Avatar
You can use a MityVac to check the solenoid valve. Make jumpers to energize the valve from the battery. Check that it opens & closes. But it sounds like it closes OK when you unplug it.
Then there's the vacuum hoses, one going down to the canister. A bigger hose for the purge flow comes from there to the intake. The vacuum-controlled valve on the EVAP canister might be sluggish? That way it's staying open too long when the ECU only wants to open it for a moment??
mccordelectric
Oct 18, 2010 08:56 AM
cidery
Aug 10, 2006 07:06 AM
SurferX
Aug 28, 2002 04:36 PM
Evil DOHC
Sep 24, 2001 04:36 PM
