h23 vtec redline?
Old Oct 19, 2004 | 04:43 PM
92hondalude's Avatar
Default h23 vtec redline?
IF i get oil squirters for my h23 vtec will i be able to rev to 7800 like a h22?
If not what do i need to do to the crankshaft so it can
Old Oct 19, 2004 | 04:49 PM
Shaun92lude's Avatar
Default Re: h23 vtec redline? (92hondalude)
i also have an h23 si... where are you getting your vtec head? will an h23vtec produce the same horsepower as an h22?
Old Oct 19, 2004 | 04:50 PM
spnbb2
Guest
Posts: n/a
SEARCH
Old Oct 19, 2004 | 04:51 PM
Default Re: h23 vtec redline? (Shaun92lude)
more because the h23 has a bigger displacement
i get my head from ebay for 455$ shipped
Old Oct 19, 2004 | 04:52 PM
Default Re: (spnbb2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spnbb2 &raquo;</TD></TR><TR><TD CLASS="quote">SEARCH</TD></TR></TABLE>
i have i never found anything on it
Old Oct 19, 2004 | 05:46 PM
spnbb2
Guest
Posts: n/a
click on archives when searching, theres hundreds of pages with info
Old Oct 19, 2004 | 05:51 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spnbb2 &raquo;</TD></TR><TR><TD CLASS="quote">click on archives when searching, theres hundreds of pages with info</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Search Engine That is Smarter Than YOU!!!! &raquo;</TD></TR><TR><TD CLASS="quote">» Search Results
Your search for h23 vtec returned 168 results.</TD></TR></TABLE>
Old Oct 19, 2004 | 06:47 PM
Default Re: (Hawkze_2.3)
ve read for 2 hours can some one just say how i can get my h23vtec safly rev to 7800 rpms
Old Oct 19, 2004 | 08:59 PM
Freemantle's Avatar
Default Re: (92hondalude)
Don't. Most of the H23VTEC death stories start with "I was taking it up to 8,200 rpm when..."
Old Oct 19, 2004 | 09:34 PM
LudeyKrus's Avatar
I rev my H23 VTEC to fuel cut daily. That's 7600 RPM for those of you n00bs. Haven't had a problem related to it yet.
Oh, and BTW: I opted to NOT install the oil squirters in my motor. They're only good for extended periods of very high RPM's, IMO.
Old Oct 20, 2004 | 04:11 AM
H23vtecEG's Avatar
Default Re: (Freemantle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Freemantle &raquo;</TD></TR><TR><TD CLASS="quote">Don't. Most of the H23VTEC death stories start with "I was taking it up to 8,200 rpm when..."</TD></TR></TABLE>
LOL............ well i was taking mine to about 8300 max when pop goes the rod bearing. anyways im building another one now and this one would rev to about 7600 no need to bring it higher. if you need something that revs higher go with h22
Old Oct 20, 2004 | 11:46 AM
Default Re: (H23vtecEG)
so just rev to stock h23 vtec?
They dont make a performance crank for h23 so you can rev higher?
Old Oct 20, 2004 | 12:08 PM
DLB1994's Avatar
if the engine good i would think it would peak power around 7500 with stock cams so theres no point to take it over 8grand so i would maybe go to 7800rpms so u can keep the good shift points and stay in the power zone
nothing wrong with reving it over 8grand with a h23 crank it the engine makes power up there
i rev mine to 8,000rpms with a h23 head still
Old Oct 20, 2004 | 12:19 PM
tarheelsoldier's Avatar
Default Re: (DLB1994)
as long as you crank, head and everything else is stock (internals for block) are the same or with high comp pistons, you should be aight. just be careful after 7500 or so. read SatanSRV's thing. he has an h23vtec (or had) that went bad. personnally i wont go over 7500 once i do my Vtec conversion.
Old Oct 20, 2004 | 02:19 PM
i never said anything with going to 8 grand i just wanted to see if it can go to h22 redline. i will just never go over 7200 or so
low13da9
Dec 3, 2007 06:00 PM
teamredline9k
Jun 2, 2006 10:44 AM
kr3nse0ulja
Dec 10, 2004 01:39 PM
foshizllmynizl
Aug 21, 2004 03:41 AM
shyboy_02
Sep 28, 2003 09:12 PM
