coilovers???
Old Dec 18, 2001 | 08:59 AM
Rob!'s Avatar
Default coilovers???
Is it a good idea to get coilovers for my crx? what are the good/bad things about them and what kind should i get and where do i go online to get them?
[Modified by RaceFacer, 6:00 PM 12/18/2001]
Old Dec 18, 2001 | 09:04 AM
REX VT's Avatar
Default Re: coilovers??? (RaceFacer)
Pro's:
-Perfect on-the-fly height adjustment
-Fits on stock/ current shocks
Con's:
-If the shocks are worn or too soft for the coilsprings you get a bounchy ride
-Shock/ spring mismatch you will not get handling you want
Which ones to get:
Ground controls in combination with Koni Yellow!
Avoid:
Skunks.......
Old Dec 18, 2001 | 09:06 AM
markedOO1's Avatar
Default Re: coilovers??? (REX VT)
avoid: anything that's $149.95 haha..scratch that, anything under $250 pretty much. you get what you pay for w/ coilovers...
Old Dec 18, 2001 | 10:08 AM
keithv's Avatar
Which ones to get:
I highly recommend this combination as well!
Old Dec 18, 2001 | 01:30 PM
Rob!'s Avatar
where do i get them? can u give me a website to get ground control and koni yellow? thanks a lot for helpin me out!
Old Dec 18, 2001 | 05:30 PM
keithv's Avatar
Here is Ground Controls website: http://www.ground-control.com/
Also, you can get Koni Yellows from http://www.shox.com/
HTH.
Old Dec 18, 2001 | 05:33 PM
Truffle Shuffle's Avatar
Default Re: coilovers??? (breaka_1_9)
What about Tein HA's... how do they compare to the GC/Koni setup?
Old Dec 19, 2001 | 07:37 PM
J98EX's Avatar
There is pretty good deal on GC at Groupbuycenter.com right now, $274. I have the Koni Yellow GC setup going on my car soon. I am waiting on my bushing kit to get here.
-Joe
Old Dec 19, 2001 | 07:54 PM
88CRXHybrid's Avatar
Default Re: coilovers??? (JCRX)
The Teins HA's do not compair with the unmatched GC/Koni combo at all. They are MUCH better. The adjustability and quality of Teins is unmatched by a coilover sleeve and unmatched damper. I found my HA's for $980shipped. Which is less than $200 more than a GC/Koni yellow combo. So why not get the better proven combo??? And the teins are also much more adjustable. A guy is selling alot of them and they are new. he is on http://www.superhonda.org forsale forum if you want some. And no I dont work for him, just a very satisfied customer.
Old Dec 20, 2001 | 04:00 AM
keithv's Avatar
Default Re: coilovers??? (88CRXHybrid)
Not sure where your getting your pricing for the GC/Koni combo, but there is no way that the GC/Koni combo costs $1100+.
Konis = $550 (absolute max they will cost)
GC = $340 (for the custom spring rate and custom length kit)
Shipping = $20 (Konis have free shipping in the US)
So that's like $900. Round up to $950 for any misc. stuff and your under the cost of the Tein HAs.
Now, this doesn't mean that at $980 the Tein HAs aren't worth it. I am just correcting some info I think is wrong...
[Modified by breaka_1_9, 8:01 AM 12/20/2001]
Old Dec 20, 2001 | 04:43 AM
REX VT's Avatar
All shocks I´ve tried or have experienced have the tendency
to break down after a year or two.... Billsteins, APEX, H+R, Tiens, Tokico´s there´s just one shock which lasts and that´s Koni, They are so confident about their products that they give a 10 year warranty on their products....
BTW: All dutch export products are good..............
Old Dec 20, 2001 | 09:58 AM
91ReXSI's Avatar
New User
why avoid skunks!!!!!!!!!!!
Old Dec 21, 2001 | 07:09 AM
MNCRXSi's Avatar
Why avoid the cheap ones? My dad has the ricky racers on his 90 Civic and their great (we have stock struts in there and its a little bouncy) it handles way better then stock...
Old Dec 21, 2001 | 09:02 PM
Denny317's Avatar
Default Re: coilovers??? (91ReXSI)
Because they are stiff as a rock!
Old Dec 22, 2001 | 12:10 AM
NawTeeCRX's Avatar
Default Re: coilovers??? (No Boost)
My skunks ride just fine with Tokico blues. They don't even affect my bad back. The bad back wasn't due to any bad suspension setup... just from being overzealous with a heavy dj subwoofer.
Old Dec 22, 2001 | 02:05 AM
REX VT's Avatar
Actually I did quit some research before I decided between Koni+ skunks or eibach
Skunks are fricking hard (just look at the spring diameter!) and mesh up the shocks pretty fast (including Koni's which have >40mm lowering warranty void). In combination with stock / soft shocks you get a bounchy ride.
Testdrive a car with skunks and see if you like it.....but keep in mind that mounting "just" skunks isn't enough to get a stiff ride. Go all the way with the suspension (ES, shocks, struts, sways). Remeber a stiff suspension means sacrificing comfort and control.....
The stiffer the car the harder to control. I have Energy Suspension (black) + Koni and Eibach + struts&ties +40 profile tires and my car is a fricking cart! (I def. suggest not buying them if you occasionally drive on brick roads)
also read some reviews at http://www.carreview.com
P.S. Where did you get that picture from your avatar? It's from a Dutch CRX.. (LOL)
EG-SIXV-TEC
13
Sep 20, 2009 09:22 AM
VTECth1s
Jul 15, 2008 08:32 AM
Fliplm0de
Suspension & Brakes
May 14, 2006 08:12 AM
sslude
May 25, 2003 11:06 PM
VTECTIME
50
Oct 25, 2002 03:39 PM
