obd2b... obd2a...
Old Oct 19, 2004 | 02:26 PM
anfrey's Avatar
Default obd2b... obd2a...
okay, here's my little inquiry. . .
i'm dropping in a 96 d16y8 into my 00 ej8... now, my car is obd2b wired, but i know that 96-98 are obd2a. would i need to get anything extra to drop the engine in my car? a friend of mine suggested i just use the manifolds from my blown (no, not turbo) y8 and problem solved.
please advise me
Old Oct 19, 2004 | 08:51 PM
hatchi's Avatar
Default Re: obd2b... obd2a... (anfrey)
you will need to get obd2a-2b conversion harness
Old Oct 19, 2004 | 09:05 PM
anfrey's Avatar
how much do those run for?
Old Oct 19, 2004 | 09:28 PM
SiKid86's Avatar
Default Re: (anfrey)
http://www.jdmshit.com/ecu/index.html has em for 125 shipped nextday air...
Old Oct 19, 2004 | 10:35 PM
anfrey's Avatar
can't i just use my current sensors and manifolds? do i need to get this harness?
this is obd2b > obd2a... no obd1 in the equation
oh, and i can't find the obd2b>obd2a harness in the link u posted....
any and all help is appreciated.
Modified by anfrey at 2:27 AM 10/20/2004
Old Oct 21, 2004 | 03:04 PM
anfrey's Avatar
so please tell me guys... what are the differences between odb2a and obd2b, as to how the engine (d16y8) is concerned?
Old Oct 21, 2004 | 04:16 PM
dantastic's Avatar
you can use a 99-00 EX ecu instead of buying a jumper to use a 96-98 EX ecu
Old Oct 21, 2004 | 04:24 PM
mwieczorek43's Avatar
Default Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">you can use a 99-00 EX ecu instead of buying a jumper to use a 96-98 EX ecu</TD></TR></TABLE>
Does the obd2a Harness-plug fit in to the obd2b ECU if he does this?
anfrey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">you can use a 99-00 EX ecu instead of buying a jumper to use a 96-98 EX ecu</TD></TR></TABLE>i have my 99-00 p2p ecu, which i intend to use. i acn just use this ecu, and my 99-00 manifolds and everythign should be okay, right?
Old Oct 21, 2004 | 04:27 PM
anfrey's Avatar
Default Re: (mwieczorek43)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mwieczorek43 &raquo;</TD></TR><TR><TD CLASS="quote">Does the obd2a Harness-plug fit in to the obd2b ECU if he does this?</TD></TR></TABLE>all my stuff is obd2b. the harness, the ecu, the manifolds... everything EXCEPT for the engine. please guide me.
EF Driver
Aug 14, 2007 03:45 AM
Eaglekper0046
Sep 27, 2005 09:41 AM
igone916
Jan 30, 2005 06:49 PM
jdmlife
Oct 14, 2004 07:17 PM
goat442003
Jun 21, 2003 07:16 PM
