rear seat question!
Old Oct 19, 2004 | 12:47 PM
untitledsn41's Avatar
Default rear seat question!
the edges of the bottom part of my rear seat always pop up like they are un-attached. i have noticed this in my friends hatch and mine. is there a way to hold them down any better? or does anyone have any tricks to keep the corners from popping up?!
Old Oct 19, 2004 | 12:50 PM
=GAME='s Avatar
Default Re: rear seat question! (untitledsn41)
is the hook in place? theres a hook on each corner to hold it down.
Old Oct 19, 2004 | 12:52 PM
Default Re: rear seat question! (=GAMEOVER=)
i just looked and there is only hooks in the front. the 2 back corners always pop up and it looks like ish!
Old Oct 19, 2004 | 01:15 PM
cSpEk's Avatar
man i have the same damn problem i also wonder how to fix that
Old Oct 19, 2004 | 02:40 PM
jbs's Avatar
jbs
I had the same problem. The cushion has warped. I used to buckle the seatbelt on the back to keep the corners from sticky up but eventually, I had to replace the bench to solve the problem.
Old Oct 19, 2004 | 04:02 PM
Mikerocosms's Avatar
Default Re: (jbs)
Just take the bench off and bend it back. I had this happen in my 93 hatch. I took the seat off and bent it back. The foam on the inside has a wire skeleton that can be bent fairly easily. Its easier if you have the bench off first so you can bend it just a touch more than necessary so it holds its shape better when put back in.
Mike!
Old Oct 19, 2004 | 08:08 PM
Default Re: (Mikerocosms)
sweet! i think ill try that out tomrorow and find out how well it works! thanks
Axemurderer23
Sep 17, 2007 11:29 PM
JoeDaSoto
Nov 5, 2006 11:37 AM
Stinkycheezmonky
Feb 11, 2005 10:23 AM
