how to make ur own msd rev pills
well its easy all u need are restiors because thats all that the pills are but the are all diff ohms...u can get these at radio shack 4 99 cent pack of 4....get a pill that is higher or lower than what u want mesure the ohm of the msd pill and find a res.. that is lower or higher than that...every 1k ohm u might gain or lose 250to500 rpm im not sure cause i have not done much reserch on diff pills..for ex i needed a pill lower than 3000 so i mesure the ohm of the 3 grand and just went with a lower ohm res...go ahead and give it a try
if you run vtec and you are obdo, you can run an MSD RPM activated switch, This switch needs RPM pills that engage the switch at a certain rpm and then gives 12V to the vtec solenoid. Im getting a y8 swapped in friday, and im running the msd, my mechanic said i can use one of his, but now i might look into this, thanks paatner
I was sent this link. Unable to place what the hell was going on. So I reread the post a few times still unable to figure out what he was talking about. So I scrolled through the poll 'choices' LOL. I would like to accept this nomination for president on behalf of all polar bears slaughtered in this years Thanksgiving hunt.
CRX Forum
CRX Forum
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Proper »</TD></TR><TR><TD CLASS="quote">Very interesting concept. I may have to try this out</TD></TR></TABLE>
Somebody help me fully understand how to do this...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SQURL »</TD></TR><TR><TD CLASS="quote">what the hell are rev pills</TD></TR></TABLE> They are pills you can take to increase your human redline, so your legs can maybe keep up with you when trying to run downhill.
Nah, there little thingos you put in your MSD ignition system to change your rev limit.
When you buy a msd 6al it comes with a built in rev limiter. you can control how high you car is able to rev buy placing these pill shape things on the bottom of the msd, the rev limiter is there to help you not over rev your engine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmEKCivic »</TD></TR><TR><TD CLASS="quote">When you buy a msd 6al it comes with a built in rev limiter. you can control how high you car is able to rev buy placing these pill shape things on the bottom of the msd, the rev limiter is there to help you not over rev your engine</TD></TR></TABLE>
dang, that's crazy. is this something MSD initially sold and ppl just found out a cheaper way to do it or what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 »</TD></TR><TR><TD CLASS="quote"> They are pills you can take to increase your human redline</TD></TR></TABLE>
LMFAO
LMFAO
Damn, its threads like these that make me realise just how incredibly stupid most of the people in this forum are.
Good info B SERIES US, not many people are aware of this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja »</TD></TR><TR><TD CLASS="quote">
Yep good info, although I'm going with the autometer shift light that does not use the pills, still good info.
</TD></TR></TABLE>Yep good info, although I'm going with the autometer shift light that does not use the pills, still good info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatRicerDaniel »</TD></TR><TR><TD CLASS="quote">its to make the rev limiter drop lower man.</TD></TR></TABLE>
No its not, its for the autometer shift light.
Pills
Pills
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">
Pills
In my eye.
Pills
</TD></TR></TABLE>In my eye.
