Car won't start...?
Old Dec 18, 2001 | 07:55 AM
1hottEG6's Avatar
Default F*#ked up, unplugged spark plug wire from distributor, car won't start, need help asap
Aight guys need a lil help, Im runnin a b20 in my hatch . started the car and popped the hood cause it revs weird (car starts off at 4 grand)*needs a new IAC..So i was poppin the hood to unplug the IAC so it revs lil better.The door closes and I got locked out, so i didn;t know how to shut the engine off...So i unplugged a spark plug wire.From the distributor..I finally get back in the car, plug the wire back in...CAR WON'T START...what did i do..?
[Modified by B20eg, 5:24 PM 12/18/2001]
[Modified by B20eg, 5:32 PM 12/18/2001]
Old Dec 18, 2001 | 01:31 PM
Perfectionist's Avatar
Default Re: F*#ked up, unplugged spark plug wire from distributor, car won't start, need help asap (B20eg)
Maybe you fried the ignitor or coil since there was no place to discharge the high voltage with the spark plug cable removed? At the least, cylinder got flooded with raw fuel and won't pop, causing your starting problem, but unlikely.
Old Dec 18, 2001 | 08:17 PM
1hottEG6's Avatar
Default Re: F*#ked up, unplugged spark plug wire from distributor, car won't start, need help asap (Perfecti
well how much does a coil cost...and is it hard to put in...I did take the plugs out and they were soaked..they were **** anyway so i got new NGK's anyway..I was told i might be able to take the battery cable off, take the ECU fuse out let it sit for a min and try again..? any truth to that...thanks
junior40er
May 26, 2009 12:23 AM
alfredbb
May 23, 2009 04:18 PM
Cameron60
Feb 19, 2009 10:22 PM
desiromeo812
Dec 18, 2008 05:35 PM
reese
Sep 2, 2002 11:59 PM
