Help me chose a revlimit
Old Dec 18, 2001 | 07:42 AM
HX_Guy's Avatar
Default Help me chose a revlimit
Im getting a P28 ECU rechiiped for the B20VTEC, but I have no idea what I should set the revlimiter to.
I was thinking 9,000 but that maybe to high and not needed..unless it makes peak power at 8500 or something.
What would you guys recommend?
Old Dec 18, 2001 | 07:43 AM
B18CXr's Avatar
Default Re: Help me chose a revlimit (HX_Guy)
unless you build the bottom end good, 8200-8500 max........9 is crazy
Old Dec 18, 2001 | 07:46 AM
HX_Guy's Avatar
Default Re: Help me chose a revlimit (B18CXr)
I have Eagle rods, Endyn pistons and a GSR girlde
Old Dec 18, 2001 | 07:47 AM
SpoonCivic's Avatar
New User
if ur using ITR cams..i believe they only make power to like 82000rpm..so there would be no point to go over stock revlimit which is 8400rpm
if ur using spoon cams..i was told by alan at AJR they make power upto 9000rpm..thats why im moving my revlimit to 9200rpm.
Old Dec 18, 2001 | 08:03 AM
TypeR0149's Avatar
Default Re: Help me chose a revlimit (SpoonCivic)
Man 82000rpms seems very High for stock cams, you may want to upgrade you valve springs, because 82000rpms, might float a valve, or blow it out the top of you hood
Man its so slow at work, i have no clienets
[Modified by Vegeta, 12:04 PM 12/18/2001]
Old Dec 18, 2001 | 08:09 AM
SpoonCivic's Avatar
New User
Default Re: Help me chose a revlimit (Vegeta)
the stock ITR valvetrain is okay until about 9000rpm. I think if his revlimiter stays at 8400rpm, he should have no need to change the valvetrain.
Old Dec 18, 2001 | 08:10 AM
B18C5-EH2's Avatar
Former Moderator
Loved
You trust the big-block to 9000? I know T.O.O does, and I'm sure you've spoken with Larry if you've got some ENDYN stuff, so ask him. He knows his **** better than anyone else knows his ****.
I would think around 8400 would be the MAX I'd go safely. I keep hearing about cams making good power up to 9000RPMs, but I have yet to SEE it yet. Someone prove me wrong by posting some dyno plots of a Honda motor making peak power around 9000RPMs and then I'll shut up about it.
Old Dec 18, 2001 | 08:13 AM
HX_Guy's Avatar
Default Re: Help me chose a revlimit (B18C5-EH2)
Muahahahaha...you asked for it...stayed tuned
Old Dec 18, 2001 | 08:18 AM
HX_Guy's Avatar
In your face biatch!
Now..I know it really stops at 8800-8900...but that is because he hit his revlimiter. You can easily see the car was still making STRONG power...hell its a straight line from 8000-9000! And a peak torque at 7800! Thast nuts!
Old Dec 18, 2001 | 08:23 AM
Cosworth's Avatar
How about 15,000 rpm? What's that car in GT2 w/ twin motocycle engine... heh.
Old Dec 18, 2001 | 08:24 AM
HapaHaole's Avatar
what cams are those on the dyno? i make 160 ft lbs at 5200. anyway my rev limit on stock ITR top end is set at 9k. ive taken it to 9, well, ive smacked int oteh limiter at the track and the motor is strong. i just forgot to shift. no need going past 8500 on the stock tach tho because it doesnt make any more power. in fact, i should shift early just so that im in my max torque range. anyway i wouldnt mind making more top end power as well so cams?
Old Dec 18, 2001 | 08:28 AM
HX_Guy's Avatar
Default Re: Help me chose a revlimit (yeah LS)
That engine has JUN3s on a B20VTEC, head done by Endyn, 12.5:1 Endyn pistons, DC JDM header...tahs tpretty much it.
Damn..160 FT @ 5200 is NICE! Whats the setup?
Old Dec 18, 2001 | 08:29 AM
HapaHaole's Avatar
same setup but stock top end baby!
and some tuning
Old Dec 18, 2001 | 08:30 AM
HX_Guy's Avatar
Damn..what HP are you making? Stock ITR cams as well? 12.5:1 compression? What header...details...I NEED DETAILS!
Old Dec 18, 2001 | 08:37 AM
Black R's Avatar
25 Year Member
Ok, what setup is this?!
Old Dec 18, 2001 | 08:41 AM
HX_Guy's Avatar
Default Re: Help me chose a revlimit (Black R)
Read 4 posts up
Old Dec 18, 2001 | 08:42 AM
HapaHaole's Avatar
Default sheeeeyeiiiiiissit
well, not nearly as much power as that motor on the dyno...210 whp. same header, same psitons, same rods...i guess i have a bad *** ecu dont i
Old Dec 18, 2001 | 08:44 AM
HX_Guy's Avatar
Default Re: sheeeeyeiiiiiissit (yeah LS)
yea LS: Am I guessing right when I guess Hondata? And are you using stock ITR cams?
BlackR: That guy's setup is:
b20/vtec, Endyn RW high compression pistons, 3 layer b20 gasket, endyn ported head, 310 injectors, 255 lb/hr high psi walbro fuel pump, eagle rods, 9 lb flywheel, msd 6al, jdm dc header, endyn ported ITR intake manifold, jg 64mm tb, homemade 3" cai and of course, jun3 cams, chipped P28 with a stock jdm b16a program w/ raised rev limit.
Old Dec 18, 2001 | 08:50 AM
HapaHaole's Avatar
Default Re: sheeeeyeiiiiiissit (HX_Guy)
honestly that motor sounds likea lot of work. my build was very easy to make the power that i got.
310 petro squirters
stock itr petro pump
stock intake mani, stock cams, stock head, stock TB
weisco pistons
eagle rods
p28 ecu with chip, vafc hell no hondata...is that supposed to be good?
9 lb flywheel
so looks the same to me but i spend less money hahah
Old Dec 18, 2001 | 08:52 AM
SpoonCivic's Avatar
New User
i thought u were talking about ITR cams, not JUN III's.
hell ya, if ur gonna use JUN III's, they make power well past 9000rpm. but stock cams lose their breath after 8200rpm
Old Dec 18, 2001 | 08:57 AM
HX_Guy's Avatar
Yeah LS: Do you happen to have a dyno chart? Id love to see how the powerband looks.
HapaHaole's Avatar
Default Re: sheeeeyeiiiiiissit (SpoonCivic)
um, realtime ITRs figured out how to make power with stock cams past 8200 so dont bet teh house just yet
Old Dec 18, 2001 | 08:58 AM
HX_Guy's Avatar
I WANNA SEE A DYNO!!!
Old Dec 18, 2001 | 09:02 AM
B18C5-EH2's Avatar
Former Moderator
Loved
I still don't see power AT 9000 or even past it, but that's some CRAZY **** nontheless.
In MY face? HA!
Old Dec 18, 2001 | 09:04 AM
HX_Guy's Avatar
Default Re: sheeeeyeiiiiiissit (B18C5-EH2)
Oh give me a break..you KNOW if the revlimiter was higher it was make power past 9K.
