reasons for oil burning???
my oil is being used up quik. i just added a quart today after only 2000 miles. i use honda oil.
does driving around 80 on the freeway cause burning oil??
ps.. couldnt find any leaks
thanks in advance
thanks in advance
From: Salt Lake City, Chicago at heart, UT or IL, USA
If you have a GSR as your name suggests, you're probally hitting vtec quite a bit, and vtec has a tendency to burn a little puff of oil. not much, but just a little as it engages.
Reasons could be...
Bad valve stem seals
Guides need to be replaced
Rings are bad
Bad seals or gaskets
Tapping into Vtec
word is your supposed to be losing about a qt of oil between changes.
Rings are bad
Tapping into Vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicFerioViRs »</TD></TR><TR><TD CLASS="quote">Reasons could be...
Rings are bad
Tapping into Vtec
Rings are bad
Tapping into Vtec
tthomass
80
Nov 15, 2006 09:56 AM
JDM B16A
Jul 25, 2006 07:57 PM
