weird knock sensor problem...
Old Oct 19, 2004 | 10:14 AM
antivic's Avatar
Default weird knock sensor problem...
after driving around for alittle bit CEL turns on with code 23 "knock sensor" after that car goes slow but v-tec seems to still engage. i checked my knock sensor i noticed its black instead of green and 2 wires instead of 1, those 2 wires are splices together with a ground out pin. is it normal to have 2 wires? should i wire it into d3 or ground it out. Thanks...its a jdm b16 with a p30 ecu
Old Oct 19, 2004 | 11:14 AM
StupidSlowRSX's Avatar
Default Re: weird knock sensor problem... (antivic)
are you sure you didnt get your knock sensors and the oil pressure sensor confused... the knock sensor is only suppose to be 1 wire. The oil pressure sensor should be a positive and a ground.
SuperBowser707
Dec 4, 2012 07:49 AM
97blacklude
Jan 31, 2009 09:56 AM
eh2
May 7, 2007 08:53 PM
iNtEgRaGsR19
Jan 20, 2007 08:04 AM
