How to tell clutch type LSD?
Old Oct 19, 2004 | 09:54 AM
Cone's Avatar
Default How to tell clutch type LSD?
I started thinking lately about something I noticed on my car since I got it. When I make tight low speed turns the inside tire kinda does this shudder thing. When I had crappy all season tires, they would chirp a little in tight low speed turns. I don't know if this is a characteristic of helical type LSDs, but I know on my old 240SX a tight upgraded clutch type LSD would cause the rear tires to chirp in low speed turns. I have a '98 Spec motor and tranny, and I guess it might have had a Spoon/Mugen/Kaaz/Cusco/etc. LSD installed. Does anyone else have the shudder? Thanks...
-Andrew
Old Oct 19, 2004 | 10:01 AM
Mugen Mike's Avatar
Default Re: How to tell clutch type LSD? (Stealth 95 GS-R)
I get that all the time with the Mugen LSD.
Old Oct 19, 2004 | 10:22 AM
Cone's Avatar
Default Re: How to tell clutch type LSD? (Mugen Mike)
hmmm. I don't wanna have to go ripping apart my tranny to find out whats in there. I really should so I know what fluid to use. I'm using Pennzoil Synchromesh now. I suppose I would have to switch to KAAZ fluid or something if I had a clutch type.
Old Oct 19, 2004 | 10:34 AM
Willard's Avatar
jack up one side of the car and put the tranny in neutral.
you should not be able to turn the wheel in either direction (the one with a tire).
Old Oct 19, 2004 | 10:38 AM
Cone's Avatar
Default Re: How to tell clutch type LSD? (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">jack up one side of the car and put the tranny in neutral.
you should not be able to turn the wheel in either direction (the one with a tire). </TD></TR></TABLE>
is this how to tell a clutch type, or an LSD period?
Old Oct 19, 2004 | 10:42 AM
Willard's Avatar
the clutch (and locker) type will have resistance all of the time (either direction).
torsen/ratchet type will have resistance only when power is applied to the differential.
Old Oct 19, 2004 | 10:52 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
You mean one of the front wheels still need to be in contact with the ground right?
Old Oct 19, 2004 | 11:00 AM
Cone's Avatar
well, I put in neutral, jacked it up on one side (and found out in the process that the alarm on my car also has a tilt sensor, w00t) and the wheel would only turn a few inches and lock in either direction. I guess I have an clutch type LSD. Now, what tranny fluid to use?
Old Oct 19, 2004 | 11:02 AM
Willard's Avatar
Default Re: How to tell clutch type LSD? (Wai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wai &raquo;</TD></TR><TR><TD CLASS="quote">You mean one of the front wheels still need to be in contact with the ground right?</TD></TR></TABLE>
jes..
"one side of the kaa"
Old Oct 19, 2004 | 11:13 AM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealth 95 GS-R &raquo;</TD></TR><TR><TD CLASS="quote">Now, what tranny fluid to use?</TD></TR></TABLE>
I use Redline MT-90. Basically, you want to use a fluid with a friction modifier, or you can use regular Honda MTF with a friction modifier additive (which Redline makes also).
Old Oct 19, 2004 | 11:14 AM
Cone's Avatar
Silver2001BMWM3 (3:06:50 PM): so now I gotta figure out which one is in there
StaticStaticX (3:07:00 PM): lol
StaticStaticX (3:07:02 PM): gl
Silver2001BMWM3 (3:07:35 PM): yeah
Silver2001BMWM3 (3:07:41 PM): I'll have to take the ****** apart
StaticStaticX (3:07:44 PM): lol
StaticStaticX (3:07:47 PM): no thanks
StaticStaticX (3:07:53 PM): tranny &gt; you
Silver2001BMWM3 (3:08:38 PM): or find out where the motor was bought, track back to where it was shipped from, track back to who own3d a 98 Spec in Japan, learn Japanese, track down previous owner and ask him what he put in it
StaticStaticX (3:08:58 PM): lol
StaticStaticX (3:09:02 PM): that might be easier
Silver2001BMWM3 (3:10:03 PM): yup
Old Dec 7, 2004 | 08:29 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Did you ever figure out what you have????
I am going through the same thing now.
Jim
Old Dec 7, 2004 | 09:51 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealth 95 GS-R &raquo;</TD></TR><TR><TD CLASS="quote">well, I put in neutral, jacked it up on one side (and found out in the process that the alarm on my car also has a tilt sensor, w00t) and the wheel would only turn a few inches and lock in either direction. I guess I have an clutch type LSD. Now, what tranny fluid to use?</TD></TR></TABLE>
Old Dec 7, 2004 | 10:06 AM
jz98ctr's Avatar
Default Re: How to tell clutch type LSD? (ccfries)
when i bought my B18C swap it had a Kaaz LSD and that thing would chatter all day long in slow turns. I switched to a quaife...bye-bye chatter and i think for street use the quaife is better IMO.
Old Jan 28, 2008 | 09:27 PM
insidiouseg-6's Avatar
Default Re: How to tell clutch type LSD? (jz98ctr)
just picked up a itr tranny..and i thought it was a stock lsd..but after reading this,i guess i have a clutch type because of the crazy clunking i get when i turn either way..im only using honda mtf......where do i get some additive ??
Old Jan 29, 2008 | 12:58 AM
RagingAngel's Avatar
Default Re: How to tell clutch type LSD? (insidiouseg-6)
I recommend Redline MTL and Ford Friction modifier.
If you search around, I've been saying this and have used it for years with great results until I finally sold my KAAZ unit.
kluminaliti
Mar 19, 2006 09:03 PM
j87w
Mar 14, 2005 12:01 PM
Cone
Oct 20, 2004 10:33 PM
SimbaDogg
Mar 16, 2004 07:08 PM
Spade
22
Jun 15, 2002 11:39 AM
