Anybody here install a skunk2 manifold on a b18c1?
Old Oct 18, 2004 | 06:43 PM
SuicideSlide's Avatar
Default Anybody here install a skunk2 manifold on a b18c1?
Im looking for someone with first hand experience in this because I have an important question which is holding me back from finishing my swap. Please reply to me or IM me. I have pics of my dilemma, the guys in the Integra forum just couldnt help me.
Old Oct 18, 2004 | 07:04 PM
djbutler007's Avatar
Default Re: Anybody here install a skunk2 manifold on a b18c1? (Tur*bLu)
i just put one on my friends car yesterday
Old Oct 18, 2004 | 08:19 PM
Default Re: Anybody here install a skunk2 manifold on a b18c1? (djbutler007)
In order for me to seal this coolant line do I have to t tap into something else?
and this coolant line on the TB is correct?
Old Oct 18, 2004 | 08:23 PM
93lsd's Avatar
looks too me that you have it correct i would just plug it shut with a hose or something
Old Oct 18, 2004 | 10:11 PM
Default Re: Anybody here install a skunk2 manifold on a b18c1? (93lsd)
I dont know how I would beable to plug that coolant line shut. Any ideas?
Old Oct 18, 2004 | 11:31 PM
all you have to do is plug it, i got some caps from autozone it was a pack with 4 for like 1.99 i put some silicone in the cap to make sure it wouldnt leak and i put a hose clap on it and everything worked out
Old Oct 19, 2004 | 03:51 AM
youngvedder's Avatar
I took a inch long piece of hose and attached it to that small extension then i took a large bolt and put it into the other end of the hose and clamped it shut. Its been a year and no problems.....
YV
Old Oct 19, 2004 | 06:02 AM
Default Re: Anybody here install a skunk2 manifold on a b18c1? (youngvedder)
thank you so much guys, you guys have no clue what Ive been dealing with in the other forum for this answer. Since sunday that was my question, now I can finally finish my project.
https://honda-tech.com/zerothread?id=1025979
and my project-
https://honda-tech.com/zerothread?id=1025939
Old Oct 19, 2004 | 07:31 AM
user 996328629's Avatar
Dont plug that line, just loop the coolant around. Pluging the lines will put alot of pressure and will eventually break, besides you dont want ur coolant haveing any blockages.
Old Oct 19, 2004 | 08:11 AM
93lsd's Avatar
Default Re: Anybody here install a skunk2 manifold on a b18c1? (Swags04)
well mine has not broken in 3 years and its been plugged
Old Oct 19, 2004 | 03:31 PM
B_CRUZ!'s Avatar
that hose your holding is supposed to go to that open coolant line.where the hell is it connected to?
Old Oct 19, 2004 | 06:16 PM
Default Re: Anybody here install a skunk2 manifold on a b18c1? (b_cruz)
to another coolant nipple next to where the upper radiator hose goes into the block. So your telling me that everyone else on this forum is wrong? Then the hose which I have in my hand, where does it connect to?
Old Oct 19, 2004 | 06:19 PM
My personal setup, i dont have any lines going to my FITV.
Im telling you right now, do not cap off lines. Its only hurting your setup.
You can T that line into any coolant jacket.
I have mine T'd into the manifold nipple.
turboHondaWesJ
Dec 22, 2012 07:44 AM
Edwin909
Sep 8, 2012 05:37 AM
IntegraGSR1999
Jan 11, 2010 05:54 PM
B18 CYA
Jun 12, 2004 12:08 PM
BMac86
Nov 28, 2003 03:14 PM
