LS Vtec, Reliable? Best Way To Accomplish?
Old Oct 18, 2004 | 05:37 PM
The DX Rex's Avatar
Default LS Vtec, Reliable? Best Way To Accomplish?
just bought an 88 crx si with a b18b1 swap in it already. i was curious about doin LS VTEC with it and was wondering how reliable is it because i heard it typically doesnt last long. is there any it can be done properly, money doesnt really matter, so that it will last for a long long time????? also what is needed to do this, just a VTEC head and some oil lines that i know off, what else?
Old Oct 18, 2004 | 05:54 PM
SLOW EF8's Avatar
It reallly depends how its build, find a good builder then u b itte
Old Oct 18, 2004 | 06:03 PM
cd1fidy's Avatar
Default Re: (HybridEF8)
just boost it you will be much happier
Old Oct 18, 2004 | 06:04 PM
Reelizmpro's Avatar
Default Re: LS Vtec, Reliable? Best Way To Accomplish? (nyhustla2k)
Strange that they just thru in an LS engine and called it a day but I guess that's better than the D16. In your case, having the LS really doesn't help out since you have to find a VTEC head, computer, wiring harness, etc and have the head and block modified for oiling and THEN address any concerns you may have with the LS bottom end's reliability.
Old Oct 18, 2004 | 06:15 PM
mar778c's Avatar
Community Builder
Community Influencer
Check here.
http://www.importreview.com/reviews/lsvtec.html
Pretty costly
Old Oct 18, 2004 | 07:01 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: LS Vtec, Reliable? Best Way To Accomplish? (mar778c)
Go and pick up the new sport compact car mag, has a detailed DIY LSVTEC conversion article with an LS in an EF... Pick it up.
As far as relibility goes.. Use ARP rod studs, Balance and micropolish the crank, and use good bearings... you'll be fine.
Old Oct 18, 2004 | 10:18 PM
mrspeaker's Avatar
Default Re: LS Vtec, Reliable? Best Way To Accomplish? (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">
As far as relibility goes.. Use ARP rod studs, Balance and micropolish the crank, and use good bearings... you'll be fine.</TD></TR></TABLE>
YUP.. And a GSR girdle would help also..
Although u dont need it if u plan on getting the rotating assembly balanced..
Old Oct 18, 2004 | 11:06 PM
92integra_gs's Avatar
yea build the internals and make sure that you get a good builder... some people dont research throughly enough that is why some thing is always wrong...
Mr si99
Jun 22, 2005 12:50 AM
helpmeplease
Oct 29, 2004 11:31 PM
RSVTECDC4
Jul 19, 2003 06:05 AM
dacaveman
Jul 18, 2003 05:31 PM
xstalkrx
May 17, 2003 03:56 AM
