will BFG 225/50/15 drag radials fit on 99 SI wheels?
Old Oct 18, 2004 | 03:38 PM
greenmonster's Avatar
Default will BFG 225/50/15 drag radials fit on 99 SI wheels?
Old Oct 18, 2004 | 03:50 PM
Default Re: will BFG 225/50/15 drag radials fit on 99 SI wheels? (greenmonster)
anyone?
Old Oct 18, 2004 | 04:13 PM
mat's Avatar
mat
well im assuming the stock ones are 195s right. they'll fit on the rim the only problem you might run into is the bead seating correctly (seen this happen on low profiles to wide for the rim) or rubbing while you're turing cause they'll more than likely bulgelike a *****. take em to a tire place and have em test fitted.
Old Oct 18, 2004 | 04:43 PM
t0p_sh0tta's Avatar
Default Re: will BFG 225/50/15 drag radials fit on 99 SI wheels? (mat)
Check BFG's site or contact them. There should be some info on the approved rim widths for that size tire. Might even find it on tire rack.
DeLucia
Feb 17, 2011 11:43 AM
tr0n9h
Oct 16, 2005 02:49 PM
EGh22aEG
Feb 23, 2005 01:47 PM
greenmonster
Oct 18, 2004 06:09 PM
