bd1 mini me swap injectors
Old Oct 18, 2004 | 03:17 PM
civicefdx's Avatar
Default bd1 mini me swap injectors
im going from obd0 dpfi to obd1 mpfi. the obd0 injectors were low resistance and the 0bd1 were high. should i get the injector resistor and 0bd0 injectors, or no resistor and just 4 new injectors? more expensive for new ones
Old Oct 18, 2004 | 03:44 PM
4drEF's Avatar
Keyboard Humorist
Default Re: bd1 mini me swap injectors (civicefdx)
You can use OBD-1 or pre-OBD (OBD-0) injectors.
With the pre-OBD injectors just make sure you use the injector resistor box.
With the OBD-1 or even OBD-2 injectors do NOT use the injector resistor box.
Old Oct 18, 2004 | 04:38 PM
deftones0817's Avatar
Default Re: bd1 mini me swap injectors (4drEF)
obd 0 injectors make lest work so stay obd0 on injectors if you can.
DEF
accordin 2 me
Dec 16, 2011 06:00 AM
LSV_REX
May 28, 2008 06:41 AM
drSquish
Jan 19, 2006 01:54 PM
CaptinMcnut
Mar 1, 2004 02:01 PM
