Somethings draining my BATTERY!!!!!!
Old Oct 18, 2004 | 03:03 PM
WHiTETYPEs's Avatar
Default Somethings draining my BATTERY!!!!!!
alright I got an 89' honda accord lx, and I bought a new battery but something keeps draining it...what should I check to fix this problem?? Thank you
Old Oct 19, 2004 | 06:36 AM
JimBlake's Avatar
Default Re: Somethings draining my BATTERY!!!!!! (Dc2TyP3R)
Use an ammeter to measure current draw from the battery. Then start pulling fuses to see which one makes it stop...
You could check some obvious stuff like maybe the trunk light never turns off? Glovebox light? Amplifier? Alarm?
Old Oct 19, 2004 | 09:28 AM
hawkmgc's Avatar
Default Re: Somethings draining my BATTERY!!!!!! (JimBlake)
89's pending on the model, are the basic of most.
The biggest power drainer is the lights, more so the glove box light.
The door gets missaligned then WAM, dead battery without knowing it.
Sometimes there is a bad ground and then you end up with lights stuck on that you dont normally look for. So try the glove box light first. Then if that don't do it then look at it in the night and see if any other lights are still on like the door lights.
If still can not find then I would go and do the fuse thing.
stocker2shocker91
Nov 11, 2015 05:02 PM
hustlr
Oct 14, 2014 03:46 AM
teh hatton
Oct 10, 2007 07:49 AM
Mr.Speed
Dec 8, 2006 11:43 AM
Keno20
Jul 3, 2005 07:27 PM
