Buddyclub spec3+ vs. Buddyclub spec 4........
Old Oct 18, 2004 | 02:18 PM
emotionisdead's Avatar
Very Emergency!!
Default Buddyclub spec3+ vs. Buddyclub spec 4........
hey guys i have a 01 ITR with some mild work (homemade itb's, header, exhaust, etc) and was definitley thinking about going witht he buddyclub cams. which do you guys think would be better? i was thinking about just getting the fours and saying **** it., but i don't know if that is the wisest move. thanks in advance for the help.
Old Oct 18, 2004 | 02:36 PM
BERT-O's Avatar
Default Re: Buddyclub spec3+ vs. Buddyclub spec 4........ (Booyakasha)
for that setup, BC3+s
Old Oct 18, 2004 | 03:08 PM
V8SHME8's Avatar
Default Re: Buddyclub spec3+ vs. Buddyclub spec 4........ (BERT-O)
I have BC3+s on my b16. The head is milled and I have omni flat bottom valves so I am up around 10.8:1 compression. I am very happy with the cams. I bought them because I autocross the car so I wanted as much low end power as possible.
Old Oct 18, 2004 | 05:16 PM
Very Emergency!!
Default Re: Buddyclub spec3+ vs. Buddyclub spec 4........ (V8SHME8)
thanks for the help. the 3+ are also over 100 dollars cheaper so i might just go with them.
Old Oct 18, 2004 | 06:52 PM
Espec_rep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BERT-O &raquo;</TD></TR><TR><TD CLASS="quote">
for that setup, BC3+s</TD></TR></TABLE>
Yup
Unless you want to raise up the compression to take full advantage of Spec4
Old Oct 18, 2004 | 07:57 PM
humble2.0prelude's Avatar
so to be able to put the 4's to full potential you would pretty much have to build a motor like TBone's? Is this correct..
Old Oct 18, 2004 | 09:35 PM
rjay8604's Avatar
Default Re: (lsvtecBA3)
good thread, lets keep it going. I'm going 12:1, 85mm b16a with b17 crank, so i'm trying to decide on which buddy clubs.
Old Oct 18, 2004 | 09:49 PM
justBLZE's Avatar
Chopper 2 Hopper
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecBA3 &raquo;</TD></TR><TR><TD CLASS="quote">so to be able to put the 4's to full potential you would pretty much have to build a motor like TBone's? Is this correct..</TD></TR></TABLE>
Altough BC4 picked up all over powerband on Tbones motor versus Skunk2 stage 3s, they really opened up past 7K RPM, I'm sure they are very compression happy
Old Oct 18, 2004 | 11:10 PM
Odiedogcx's Avatar
AIRBORNE
Default Re: (tommy69)
hmmm ... so 81.5mm, 12.5:1 CR, and BC4 is a good combo?
Old Oct 19, 2004 | 05:14 AM
hype r 555's Avatar
Default Re: (Odiedogcx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Odiedogcx &raquo;</TD></TR><TR><TD CLASS="quote">hmmm ... so 81.5mm, 12.5:1 CR, and BC4 is a good combo?</TD></TR></TABLE>
Would BC 4's be better for this kind of setup then sk2 stg2's? My numbers in sig....
Old Oct 19, 2004 | 08:37 AM
Odiedogcx's Avatar
AIRBORNE
Default Re: (lsed-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsed-eg &raquo;</TD></TR><TR><TD CLASS="quote">
Would BC 4's be better for this kind of setup then sk2 stg2's? My numbers in sig....</TD></TR></TABLE>
Werd .... 81.5mm, 12.5:1 CR ....
Buddy Club Spec III+, Buddy Club IV, or Skunk2 Stage 2 ?
truazn4lyfe
Sep 17, 2007 05:40 AM
Jason703Racing
May 11, 2007 11:53 AM
EKBOOSTDREAMS
12
Jan 1, 2007 06:06 PM
tomlinson619
17
May 24, 2006 04:37 AM
AlLMoToRvOtEr
30
Jun 16, 2005 08:04 PM
