Is My Belt too loose?
Old Oct 18, 2004 | 01:54 PM
CircuitFG's Avatar
Default Is My Belt too loose?
Is my timing belt too loose? I've read that a 90 degree turn is ok, so does this mean i'm ok???
sorry about the quality . ... I used to low quality setting on my camera phone. . .
Old Oct 18, 2004 | 02:07 PM
xyooj's Avatar
im not an expert...but that looks loose
Old Oct 18, 2004 | 02:15 PM
Curtisbeef's Avatar
Yes way too loose
Old Oct 18, 2004 | 02:17 PM
CircuitFG's Avatar
Default Re: (Curtisbeef)
hmm. . .I thought 90 degree turns were ok . . .
Old Oct 18, 2004 | 02:37 PM
gsrboi80's Avatar
Default Re: Is My Belt too loose? (CircuitDA9)
way too loose
Old Oct 18, 2004 | 02:48 PM
rovigian's Avatar
Default Re: Is My Belt too loose? (gsrboi80)
You need to turn your crank a few times and it will tighten the belt, then you can retighten the tensioner. that belt needs to be a little tighter.
Old Oct 18, 2004 | 02:50 PM
CircuitFG's Avatar
Default Re: Is My Belt too loose? (rovigian)
right on, i'll do that tomorrow. . i'm changing my cam gears and putting in motor mount inserts tomorrow anyways. . .
Old Oct 19, 2004 | 04:08 AM
JimBlake's Avatar
I've heard about (& repeated) the 90 degree twist. But if I take off the lower timing cover, grab the belt in the middle of that long span, I can barely twist it 90 degrees. I don't think I could twist that much just in the little space of the upper cover.
Old Oct 19, 2004 | 04:24 AM
highboostb18c1's Avatar
Default Re: Is My Belt too loose? (JimBlake)
you should only be able to turn the belt at a 45 degree angle, 90 is too much, thats way to loose. use the tensioner and tighten it
Old Oct 19, 2004 | 06:01 AM
ebelp's Avatar
Default Re: Is My Belt too loose? (highboostb18c1)
How much does it flap when the engine is running?
JDM_ego2033
Jun 7, 2018 03:11 AM
slide inside
Oct 22, 2009 09:25 AM
airikkCRX
Feb 8, 2009 01:52 PM
LudeyKrus
Sep 3, 2004 11:22 AM
RCautoworks
25
Aug 15, 2004 09:17 PM
