Gas smell from tail pipes on cold starts.
Like the topic states. check my sig for setup. Im running 52 psi on the fuel regulator. Is it normal to smell straight gasoline from the tailpipes on cold starts. Car runs like a beast though. Cant complain!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swiftstyles »</TD></TR><TR><TD CLASS="quote">Is it normal to smell straight gasoline from the tailpipes on cold starts.</TD></TR></TABLE>
Um, no. I would call that 52 psi into question, as well as the "chipped" ecu.
I'm not sure what you're fuel pressure is supposed to be. I'm at 50 psi on my b16 with hose off.
I'd check the tank. Look for leaks in the fuel lines. I think fpr is ok.
venomzz
Jan 24, 2008 06:19 PM
ED609
Feb 6, 2006 07:59 AM
