Mini Me: Timing belt works its way off of cam gear :(
Old Oct 18, 2004 | 12:47 PM
whitelightnin's Avatar
Default Mini Me: Timing belt works its way off of cam gear :(
HI everyone.
just put a d16z6 head on a d15 block. new timing belt,waterpump. i have the tensioner tightened all the way with the correct belt(the one recommended in the massive mini me write up) when i start the car the belt starts to work its way off of the cam gear and also starts to slide as far over as it can on the crank gear. for some reason it seems like the cam gear, water pump,tensioner and crank gear arent lined up????? n e ideas as to what could be the cause? PLEASE help! this is shaping up to be the worst day of my year
is there only one type of water pump for the d series blocks?
Old Oct 18, 2004 | 12:50 PM
93CivicSI's Avatar
Default Re: Mini Me: Timing belt works its way off of cam gear :( (whitelightnin)
did you install the 'other' concave washer on the outside of the timing gear?
#12 on this page: http://www.hondaautomotivepart...ISTON
There is one on the inside of the timing pulley (engine side) and one on the outside of the timing pulley (timing cover side)
lurice01
12
Feb 22, 2017 07:56 PM
Ef4doorwagon
13
May 17, 2014 06:09 PM
gramentz
Feb 22, 2013 08:12 AM
DumpdEJ6
Sep 12, 2010 08:05 AM
civicnightmare
Jan 29, 2004 12:47 PM
