Just ran compression test. 180-170-180-180 good?
Old Oct 18, 2004 | 11:37 AM
JamesQ's Avatar
Default Just ran compression test. 180-170-180-180 good?
installed zex kit 2 weeks ago running on 55 shot with colder plugs. Just ran a compression test and it yielded up 180-170-180-180. Is this still good? I always thought normal compression is above 200psi. Thanks for any input.
Old Oct 18, 2004 | 11:38 AM
underpressure02's Avatar
Default Re: Just ran compression test. 180-170-180-180 good? (JamesQ)
yeah it sounds fine to me.
Old Oct 18, 2004 | 11:39 AM
Adriano's Avatar
The good thing is that they are all close to each other. What motor do you have?
Old Oct 18, 2004 | 11:41 AM
JamesQ's Avatar
Default Re: Just ran compression test. 180-170-180-180 good? (brryder)
sorry forgot to list motor.
Motor is a D16y8 from my 99 civic ex. Those numbers were done with 5 cranks each. I was wondering was i suppose to use the extention they gave me? (told me to use it for reach plugs over 14mm but mines was 12mm, although counting the top, it's 14)
Old Oct 18, 2004 | 11:54 AM
tgreaves's Avatar
Thats about what mine is on my d16y7 so I would say your good..
Old Oct 18, 2004 | 11:58 AM
m R g S r's Avatar
5 cranks doesn't sound like alot, I normally do 7-10, just to ensure the gauge stops going up. . .
Old Oct 18, 2004 | 12:17 PM
GDM Z28's Avatar
Default Re: Just ran compression test. 180-170-180-180 good? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">5 cranks doesn't sound like alot, I normally do 7-10, just to ensure the gauge stops going up. . .</TD></TR></TABLE>
5 cranks is how you do a proper comp. check.
Old Oct 18, 2004 | 12:36 PM
slrh22hatch's Avatar
Default Re: Just ran compression test. 180-170-180-180 good? (civicflnum1)
Looks good to me
Old Oct 18, 2004 | 12:45 PM
EG-CRAIG-R6's Avatar
LS TURBO WITH GERRET T3 WITH HP FUEL PUMP RC 440 INJECTORS VORTEC FMU AFC APEX AIR FUEL CONTROLLER U KNOW HOW TO TUNE THAT APP?
HELP ME OUT WIT SOME INFO MAYBE I'VE HAVENT HEARD THANKS.
Old Oct 18, 2004 | 12:58 PM
hXc-DC2's Avatar
Default Re: Just ran compression test. 180-170-180-180 good? (EG-CRAIG-R6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-CRAIG-R6 &raquo;</TD></TR><TR><TD CLASS="quote">LS TURBO WITH GERRET T3 WITH HP FUEL PUMP RC 440 INJECTORS VORTEC FMU AFC APEX AIR FUEL CONTROLLER U KNOW HOW TO TUNE THAT APP?
HELP ME OUT WIT SOME INFO MAYBE I'VE HAVENT HEARD THANKS. </TD></TR></TABLE>
Don't try to jack his thread. Start your own and I bet you'll get the answers you want aka search.
Old Oct 18, 2004 | 12:59 PM
tgreaves's Avatar
Ummm.... Are you really running this setup..
And dont hijack someones thread..
Old Oct 18, 2004 | 01:59 PM
JamesQ's Avatar
Default Re: Just ran compression test. 180-170-180-180 good? (slrh22hatch)
thx for the responces guys.
as for you, I would start your own thread to reach out to more people.
Old Oct 18, 2004 | 02:13 PM
_gurusan_'s Avatar
sorry to jack the thread...but those are almost the same results I got from my b16a3...
I got 175, 180, 178, 175
Does this mean my engine is unhealthy? I mean since my C/R is 10.2:1 shouldn't it be higher?
Old Oct 18, 2004 | 03:30 PM
Tad's Avatar
Tad
yeah those numbers are good for a dseries.
they're not the BEST, but they're good.
Old Oct 18, 2004 | 03:42 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">
5 cranks is how you do a proper comp. check.</TD></TR></TABLE>
it varies but in most cases you crank until the needle on the gauge no longer rises... for some motors its 4 others its 8.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _gurusan_ &raquo;</TD></TR><TR><TD CLASS="quote">sorry to jack the thread...but those are almost the same results I got from my b16a3...
Does this mean my engine is unhealthy? I mean since my C/R is 10.2:1 shouldn't it be higher?</TD></TR></TABLE>
yea those numbers sound low to me... 180psi is like 9:1 compression ratio. however the numbers are similar to each other so there are no distinctive problems with the motor.
Old Oct 18, 2004 | 03:59 PM
Sonny's Avatar
Don't worry too much about peak numbers. My B16A2 read:
230 psi on a Snap On gauge
210 psi on a Sears gauge
190 psi on a Matco gauge
Sonny
nevrkno
Dec 8, 2008 06:08 PM
crxowner
Mar 5, 2006 11:21 AM
ChronicGreenDC2
Jun 24, 2005 09:30 AM
spankey167
13
Sep 23, 2004 05:30 PM
