disable internal amp on an Alpine
Old Oct 18, 2004 | 10:48 AM
Spider Man's Avatar
Default disable internal amp on an Alpine
I remember people posted one how to disable the internal amp on the alpine cd players. How do you do this?
Old Oct 18, 2004 | 11:00 AM
civic_speed99's Avatar
Default Re: disable internal amp on an Alpine (Spider Man)
I think if you are running sepaate amps you have to hold down the setup button until it takes you into the menu. Then you have to scroll over to the one tat is "PWRIC" i believe and turn it off. The shuts it off and turn signal to the pre-amp outs only. That is how it is on my alpine.
Hope it works
Old Oct 18, 2004 | 12:00 PM
Spider Man's Avatar
Default Re: disable internal amp on an Alpine (civic_speed99)
which alpine you got?
Old Oct 18, 2004 | 01:41 PM
PM-Performance's Avatar
? am i missing something? do you get more voltage by switching to preamp only? i woulda just not wired the speakerlevel inputs and only used preamps. i never knew you could disable it though
Old Oct 18, 2004 | 02:23 PM
Spider Man's Avatar
Default Re: disable internal amp on an Alpine (itr206)
You don't get more voltage, you just reduce the chance of catching noise.
Old Oct 18, 2004 | 08:14 PM
cda-7893
Old Oct 19, 2004 | 01:44 AM
Spider Man's Avatar
Default Re: (civic_speed99)
I think I figured it out on mine.
Thanks.
Old Oct 19, 2004 | 04:34 AM
Xsi's Avatar
Xsi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_speed99 &raquo;</TD></TR><TR><TD CLASS="quote">I think if you are running sepaate amps you have to hold down the setup button until it takes you into the menu. Then you have to scroll over to the one tat is "PWRIC" i believe and turn it off. The shuts it off and turn signal to the pre-amp outs only. That is how it is on my alpine.
Hope it works </TD></TR></TABLE>
Thats how it works on mine
patrick4588
Audio / Security / Video
11
Feb 18, 2008 09:33 PM
skrewdriver88
Aug 24, 2004 08:21 PM
96Civic_Coupe
Jul 13, 2004 05:47 PM
jordan-boxer
15
May 8, 2004 06:03 PM
