CRAZY BUILD PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
MY PLANS :
GSR BLOCK
type-r water pump and oil pump
LS STOCK LENGTH H-Beam eagle rods
LS crankshaft polished and ls block internals (girdle and what not
12.0:1 compression pistons from JE or civic type-r pistons
b18C1 gsr head for the extra higher compression w/ skunk2
manifold
now would there be a piston to deck height difference?
would it claer the deck or smack into the head
would it just fit like a glove or what would be my clearance issues?
i know that i just have to tap the oil squirters a little to let the crank move freely but that's all i've heard
please let know your input
I HAVE SEEN THIS SET UP DO IN THE LOW 12'S WITH NO EXTRA HELP
IS THIS AN OVER ALL GOOD IDEA OR WHAT?????????????????????????????
GSR BLOCK
manifold
i just did one for the first time and in my opinion worth it compared too my other high comp gsr motor, and you dont have too worry about all that oil line crap and tapping here and there...
11sec.ALL MOTOR
do you run it on 93 octane
did you get detonation of any piston
12.5 is a little high what do you think and what pistons did you use
any issues with the set up
Bambin0
Nov 5, 2007 03:23 PM
NightmareApex
22
Dec 18, 2004 10:53 PM
tnsxsear1
Feb 8, 2004 03:33 PM
