94 honda Civic LE, when it get warm, the RPM get low and the temperature goes high
Old Oct 18, 2004 | 09:55 AM
Engineerz's Avatar
Default 94 honda Civic LE, when it get warm, the RPM get low and the temperature goes high
This is the second time that my car did this. Just when it get warm the RPM get slower to almost it feel that it is going to shut off, ant the same time the temperature gauge went up to 3/4, when I blow air to the inside it got cold little but I still didn't know what the cause the problem. Recently I changed the distributor.
Any advice would be appreciated.
Old Oct 18, 2004 | 10:39 AM
edd001's Avatar
Default Re: 94 honda Civic LE, when it get warm, the RPM get low and the temperature goes high (Engineerz)
silly question but have you checked the coolant level
Old Oct 18, 2004 | 11:37 AM
Engineerz's Avatar
Default Re: 94 honda Civic LE, when it get warm, the RPM get low and the temperature goes high (edd001)
This is the second time that my car did this. Just when it get warm the RPM get slower to almost it feel that it is going to shut off, ant the same time the temperature gauge went up to 3/4, when I blow air to the inside it got cold little but I still didn't know what the cause the problem. Recently I changed the distributor. Any advice would be appreciated.
Yep, the engine temperature is normal, I recently changed the cooling, and the engine was not that hot at all. I felt the pipe to see if there is a pressure from the thermostat to make sure it is opening. The pressure was equal on both sides of the pipes coming in and out of the radiator.
I think there is no problem with the car, I thought after checking the engine when this happened that the reading was wrong. The engine was not hot to what the heating gauge said so.
Sarah Knott
Dec 29, 2016 08:12 PM
dementia101
Mar 25, 2013 06:38 AM
Rob.
Oct 6, 2008 08:34 PM
h8tred
Dec 11, 2004 03:18 AM
intekragsr
Nov 11, 2002 05:58 PM
