D15B swap w/ JDM p08 ECU pass SOCAL smog?
Old Oct 18, 2004 | 07:02 AM
SuperDuude's Avatar
Default D15B swap w/ JDM p08 ECU pass SOCAL smog?
Has anyone pass california smog with a D15B VTEC swap and JDM p08 ecu pass somg in california? If yes, how many miles on your cat? I have a D15B VTEC w/ JDM p08 ECU that needs a smog but not sure if it will pass. I have a cat is 150000+ miles on it, curious if it will pass So Cal smog.
Anyone have a cat I can borrow?
Old Oct 18, 2004 | 11:42 AM
d16singlecammer's Avatar
Default Re: D15B swap w/ JDM p08 ECU pass SOCAL smog? (SuperDuude)
I dont think so, will like to know the answer also. THe reason I dont believe it will pass smog will be that engine and ECU was never available in the U.S. CA smog sucks big *****, Im also planning on running the same set-up you have there. When smog comes along Im going to cheat it , the only way around it.
Good Luck
Old Oct 18, 2004 | 12:58 PM
Default Re: D15B swap w/ JDM p08 ECU pass SOCAL smog? (d15singlecammer)
ill pass the smog part but not visual or function. BUMP would like to know a definite answer
Old Oct 18, 2004 | 07:15 PM
SuperDuude's Avatar
I also have p05 ECU from my D15B7 non vtec... wonder if this ECU will pass... cause I read somewhere that p08 have the leanest fuel map ... We'll see when friday rolls around.
Old Oct 18, 2004 | 11:41 PM
Good luck, make sure to post the outcomes. Bump
Old Oct 19, 2004 | 09:49 AM
HumanResource's Avatar
In REALITY the smog rep will not question it if it looks STOCK and if it has all the proper SMOG EQUIPMENT UNLESS he's a Smog ****.
They'll proly hound you more on the CAT than the engine if it looks stock enough. Open Wires, Shiny INtakes, headers, these will make the guys think twice, you don't want that.
The STOCK engine runs hella clean with the STOCK ECU (it's a HONDA!!!)
I'd recommend getting a bottle of the GUARANTEED2PASS stuff avail from CRC. Drops the readings quite a BIT.
Good Luck Bro.
Old Oct 21, 2004 | 07:51 AM
USDMGD3!'s Avatar
hey keep us posted cuz im thinking of picking up a d15b for the hell of it...
Old Oct 26, 2004 | 10:06 PM
Ignitecivic's Avatar
Default Re: D15B swap w/ JDM p08 ECU pass SOCAL smog? (OZ Rally)
i heard that a d15b will pass smog since they just look at the motor and if everything is completely stock , they wont say anything. if they check the code it will read D15b pretty much lookin like a dx or cx. when i did my test only on my d16z6 they mostly worried bout any aftermarket parts to the motor and passing emission test.
Old Oct 26, 2004 | 10:42 PM
Calvinator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperDuude &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone pass california smog with a D15B VTEC swap and JDM p08 ecu pass somg in california? If yes, how many miles on your cat? I have a D15B VTEC w/ JDM p08 ECU that needs a smog but not sure if it will pass. I have a cat is 150000+ miles on it, curious if it will pass So Cal smog.
Anyone have a cat I can borrow?</TD></TR></TABLE>
A garrenteed way to pass the smog with a jdm d15b is to swap the head to the head that came with your car. I've seen it done to my friends car (bluracer). He has a 95 vx, so we just put a vx head with the p07 ecu and it passed. I guess they thought it was a d15z1.
I know this seems like a hassle, and it probably is. I would only do this if you have no other ways to pass with that motor. If you can find another way, use that.
Old Oct 26, 2004 | 11:26 PM
Eskay@JDMCircle.com's Avatar
put the non-vtec ecu in, make sure your cats not blown out, you should pass pretty easily from there?
dylokjai
Mar 12, 2007 12:41 AM
the soL that could
Mar 8, 2006 12:57 PM
FOMULA91
35
Mar 23, 2005 09:31 AM
Honda_RN
Jul 6, 2004 10:19 PM
spookhatch24
Mar 18, 2003 06:33 PM
