Removed AirFilter (losspower)
Old Oct 18, 2004 | 04:58 AM
TheWickedOne's Avatar
Default Removed AirFilter (losspower)
The other day i dyno'd the car, so just for Ha'Ha's i was trying different things. I guess it really all depended on what we tuned the car with .. But.. i took the filter off and loss 15 horse, I threw back on and the outcome was 487@the wheels. I was in Aww.... Just wanted to share this..
Old Oct 18, 2004 | 05:58 AM
Burke's Avatar
Banned
Default Re: Removed AirFilter (TheWickedOne)
did you a/f get leaner without the airfilter???
Old Oct 18, 2004 | 06:36 PM
Fkned's Avatar
Default Re: Removed AirFilter (Burke)
The real question is do you know why it made more w/the air filter?
Old Oct 18, 2004 | 06:44 PM
HYBRID_H@TCH's Avatar
Default Re: Removed AirFilter (Ed's Racing Heads)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ed’s Racing Heads &raquo;</TD></TR><TR><TD CLASS="quote">The real question is do you know why it made more w/the air filter? </TD></TR></TABLE>
I dont..care to shed some info?
*edit*
thanks for the answer ed...
Modified by 99Hybrid_Hatch at 7:54 PM 10/18/2004
Old Oct 18, 2004 | 06:53 PM
Rtype16's Avatar
Default Re: Removed AirFilter (99Hybrid_Hatch)
This is most likely on a turbo car. The inlets of the turbo do have a tper to them, but it always helps out more with the venturi which usually on the inside of the filter.
Old Oct 18, 2004 | 07:18 PM
Fkned's Avatar
Default Re: Removed AirFilter (Rtype16)
kind of close but not quite there.
Old Oct 18, 2004 | 07:34 PM
HybridKOOP's Avatar
Probably drew hotter air in from the manifold without the filter? I dunno.. just a stab
Old Oct 18, 2004 | 07:40 PM
Fkned's Avatar
Default Re: Removed AirFilter (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">Probably drew hotter air in from the manifold without the filter? I dunno.. just a stab</TD></TR></TABLE>
nope
Old Oct 18, 2004 | 08:00 PM
Fabman's Avatar
Lierley Fab
looking for your 15mins of fame
Old Oct 18, 2004 | 08:01 PM
Suprdave's Avatar
Default Re: Removed AirFilter (Fabman)
hahahah
Old Oct 18, 2004 | 08:02 PM
Fkned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fabman &raquo;</TD></TR><TR><TD CLASS="quote">looking for your 15mins of fame </TD></TR></TABLE>
Not at all but if it's just told to you w/o thinking what did you really learn?
Old Oct 18, 2004 | 08:05 PM
Trooper's Avatar
Aeration ?? proper atomization of the fuel and air? I don't know to much about turbo but i know this is a big factor with all motor cars.
Old Oct 18, 2004 | 08:11 PM
Fkned's Avatar
Default Re: Removed AirFilter (Trooper)
The air filter straigtens the air going into the tube,like a radius edge when flow bench testing.W/O the filter the air catches the edge and tumbles around for a while.Thats why shawns magic air tube makes power,well one of them.It has a massive radius on the front end.
Old Oct 18, 2004 | 11:11 PM
BoostedJeff's Avatar
hmm, didnt know that
***goes back into garage and puts back on fliter***
Old Oct 18, 2004 | 11:36 PM
Rtype16's Avatar
Default Re: Removed AirFilter (JDMHatch4Me)
A big *** radius is not neccesarily what you want all of the time. This can actually slow down the air. A smaller proper raidus is usually what works best. Typically found in AEM, K&N and Airaid filters. Not a huge *** radius like some people run on there drag cars.
Old Oct 18, 2004 | 11:45 PM
Fkned's Avatar
I think you missunderstood me alittle,I didn't say big radius's were why the motor made more hp w/the air filter .I said it straighted out the air like a radius does.Radius sizing is whole other topic.That's just something you have to test and tune to get right by trial and error.
Old Oct 19, 2004 | 10:59 PM
prestonpark's Avatar
myabe u lost power cause ur car was on a dyno and not moving like 100 mph which gives u massive air just a thought
Old Oct 19, 2004 | 11:14 PM
ATS*Mark's Avatar
OG triple OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtype16 &raquo;</TD></TR><TR><TD CLASS="quote">This is most likely on a turbo car. The inlets of the turbo do have a tper to them, but it always helps out more with the venturi which usually on the inside of the filter.</TD></TR></TABLE>
whats a better venturi , convergant or divergant?
Old Oct 19, 2004 | 11:48 PM
flip1199's Avatar
Default Re: Removed AirFilter (Hella_JDM)
now my question is... if i attached a 8in straight pipe will that be better then no pipe? would it be better then with a filter?
pcguy760
Oct 16, 2008 07:02 PM
HondaHeddie
11
Oct 6, 2006 08:35 PM
dangerranger21
Jun 15, 2006 08:30 AM
ICeDoUt
24
Apr 6, 2006 09:48 AM
SuzukaBlueAP2
May 26, 2003 12:40 AM
