91 EX Coupe will not start after sitting all day.
Old Oct 18, 2004 | 03:39 AM
superjudge's Avatar
Default 91 EX Coupe will not start after sitting all day.
I get up at 6am leave at 7am, and the car starts right up. I work until 3:30pm, sometimes 4 or 5pm, and when I go to leave, sometimes every day, the car won't start for anywhere between 3 - 10 minutes. I crank it a few times, and it always cranks, let it sit for a minute, and try a few more times, and eventually it starts.
What could be wrong, do you suppose?
Old Oct 18, 2004 | 06:59 PM
PrettyLude's Avatar
main relay
Old Oct 18, 2004 | 09:44 PM
patastinky's Avatar
Default Re: (PrettyLude)
yup
Old Oct 18, 2004 | 10:50 PM
Monkey Fing a Coconut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">main relay</TD></TR></TABLE>
try lightly kicking where the fuse box is under the dash while trying to start and see if it helps in starting..
Old Oct 19, 2004 | 05:59 AM
superjudge's Avatar
Default Re: (twistedbydezign)
It seems resounding, I saw it in another thread after doing some reading, I'm going to check that out if it stalls today, I'm going to running the air first, if you don't mind, I'll hold off on kicking it
Thanks a lot guys, watch for good news.
By the way, how much does one of those cost if I replace it?
Old Oct 29, 2004 | 03:20 AM
superjudge's Avatar
Default Re: (superjudge)
It hasn't been giving me any problems since I posed, just thought I'd update since you haven't seen me.
Old Oct 29, 2004 | 09:49 AM
KatyHonda's Avatar
A main fuel relay can be highly intermittent, sometimes going weeks or months between failures to start.
You can pull the relay and resolder the joints to fix. Broken solder jts due to thermal cycling are the problem.
I grew up in Tifton, Ga a few miles from you many years ago, but don't get back there much anymore. Albany's a nice town.
Regards
Old Nov 2, 2004 | 12:39 PM
superjudge's Avatar
Default Re: (KatyHonda)
The car wouldn't start at all today. I tried running the heater a bit to see if it would help, because it helped somebody else. It would not start, though. My battery is almost dead, now, too. My fuses are under the hood, just in front of the passenger side, but I don't know where the main relay is. I'm going to check my Haynes manual, but if anybody knows, let me know.
Old Nov 2, 2004 | 06:38 PM
PrettyLude's Avatar
main relay is underneath the dashboard on the driver's side, and held on by two goldish 10mm bolts
Old Nov 2, 2004 | 06:55 PM
Teglessb18's Avatar
main relay Same happened to me.
Old Nov 2, 2004 | 09:24 PM
momstaxi's Avatar
Default Re: 91 EX Coupe will not start after sitting all day. (superjudge)
definatly check the ICM located inside the distributer, i had problems identical to that and it was the cause.
Old Nov 4, 2004 | 03:27 AM
superjudge's Avatar
Default Re: (Teglessb18)
It started right up when I went back at about 9:30pm, like I was just starting it up to take it off the car lot.
I've gotten a new solder gun and I'm going to tackle the relay Saturday.
If I have another problem with it, I know where it is now, I can probably just flick it.
Old Nov 4, 2004 | 04:45 PM
KatyHonda's Avatar
Main relay is nearly impossible to see from directly beneath the dash. I've found that removing the cruise control module ( 3 bolts?) near the steering column allows it to be seen and removed w/ relative ease. As someone said, remove the 10mm socket size, bolts holding the MFR bracket to the body rather than trying to separate the relay from the bracket. It's a gray relay, ~ 2x2x2 w/ 7 wires leading to the relay and an 8-pin connector to the relay.
good luck
Old Nov 18, 2004 | 03:11 AM
superjudge's Avatar
This is definitely not the easiest part to get out of your car.
ArtyTheKid
Feb 6, 2015 02:08 AM
Getsch
Aug 19, 2005 11:05 PM
5thgencivicr
11
Aug 14, 2005 08:36 AM
wyldbil
Sep 7, 2004 12:25 PM
eL
11
Aug 5, 2004 03:00 PM
