Question about using Hondata IM gasket on boost applications...
Old Oct 18, 2004 | 02:33 AM
AzntaggeR's Avatar
TSPeed Factory
Default Question about using Hondata IM gasket on boost applications...
i was told that hondata's intake manifold gaskets are good for NA applications, but are worthless in forced inducted setups. just deciding whether or not to buy one for my turbo setup once i start putting everything together. can anyone vouch for this bit of information? i plan on using this with a skunk2 intake manifold on a B18C1.
Old Oct 18, 2004 | 02:59 AM
grndcont's Avatar
Default Re: Question about using Hondata IM gasket on boost applications... (AzntaggeR)
why would it be worthless in a f.i. setup? it does the samething in that situation as an n.a. ( lowers itakemanifold temps). i have one and most the other f.i. guys i know do too, they work great (slightly lower temps, meby 20-50 degres).just get one, youll like it.
Old Oct 18, 2004 | 03:00 AM
Finland's Avatar
the person that told you that is.....worthless.
The Hondata Heatshield does exactly the same thing on a boosted application as it does on a non-boosted application.
I've been running the gasket for a couple of years now...no issues.
Old Oct 18, 2004 | 04:19 AM
HYBRID_H@TCH's Avatar
Default Re: (boost psycho)
I use mine on my boosted car..works great..28+ psi and never a problem and great charge temps.
Old Oct 18, 2004 | 04:29 AM
Rod.'s Avatar
https://honda-tech.com/zerothread?id=897065
here is a 3 page thread on hondata gasket I started back then
might have your answer
Old Oct 18, 2004 | 07:39 AM
PM-Performance's Avatar
Default Re: Question about using Hondata IM gasket on boost applications... (redturbocivic)
i noticed a big diff when i put one on my car. worked great and did what it was supposed to
Old Oct 18, 2004 | 07:41 AM
j-robsDA's Avatar
Default Re: Question about using Hondata IM gasket on boost applications... (itr206)
sounds interesting, might have to try this. After all, I am getting a new head and intake manifold. Now would be the perfect time.
Old Oct 18, 2004 | 03:31 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Question about using Hondata IM gasket on boost applications... (j-robsDA)
ok thanks for the re-assurance. the reason why i ask is because i thought maybe if the air was being forced inducted to the intake manifold that it would cause the honda IM gasket to heat up even more causing the IM to get heat soaked anyways. thanks for the replies, i'll probably end up buying one now for the skunk2 IM i plan on installing.
pcguy760
Apr 13, 2011 11:08 AM
lwct100
Sep 21, 2010 01:13 PM
polishedturd
Apr 23, 2008 09:53 AM
huevosrancheros
Oct 14, 2006 09:33 AM
btole
Oct 27, 2003 04:57 PM
