JDM ITR + harness swap - VTEC oil pressure switch?
Old Oct 18, 2004 | 01:31 AM
CivicESi's Avatar
Default JDM ITR + harness swap - VTEC oil pressure switch?
I am doing a JDM ITR swap into a RHD JDM Vti (EG4) witha Kenji P28 ECU, retaining the JDM ITR engine harness (both RHD )
The JDM ITR harness doesnt have the connectors or wiring on there, for the pressure switchg, so how do wire it up with no CEL's
Will the A4/D6 splice fix it all, or do i need to sort out a ground. If so where too/from
I am selling the old motor and harness, so need to keep it intact, so have no solenoid and connecors to do the easy fix
any suggestions, or am i trying to fix a non existant problem
Old Oct 18, 2004 | 05:43 AM
JinDIESEL's Avatar
Default Re: JDM ITR + harness swap - VTEC oil pressure switch? (CivicESi)
A4 to D6 solves this.
Old Oct 18, 2004 | 05:54 AM
Jon D's Avatar
Default Re: JDM ITR + harness swap - VTEC oil pressure switch? (JinDIESEL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JinDIESEL &raquo;</TD></TR><TR><TD CLASS="quote">A4 to D6 solves this.</TD></TR></TABLE>
lol....if anybody should know its you dood
Old Oct 18, 2004 | 08:51 AM
CivicESi's Avatar
Cheers, i thought it might, but wanted to be sure, just spent nearly $5k on a B18C-R swap, wanted to be 100% sure VTEC would be up and running
Plus my setups a little unusual being US P28ECU, JDM chassis loom, JDM engine loom, JDM engine
Slopoke got me the answer i wanted in the end
the VTEC solenoid, A4, is grounded too, so when you splice, when the solenoid goes 12V, both switch to 12V, and when it goes back, both ground
Picking the car up tomorrow so should be able to test it out then
Old Oct 25, 2004 | 12:33 PM
JinDIESEL's Avatar
Default Re: JDM ITR + harness swap - VTEC oil pressure switch? (B18C-Rsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C-Rsi &raquo;</TD></TR><TR><TD CLASS="quote">
lol....if anybody should know its you dood </TD></TR></TABLE>
haha exactly. did the vtec work? if not, just stick a paper clip into A4 and into d6. make sure it's deep enough. it should work after this.
JDM CTR EK
11
Oct 18, 2003 05:02 AM
PatrickGSR94
15
Aug 24, 2003 12:51 PM
PatrickGSR94
Aug 14, 2003 07:42 AM
JDM DC2 R
May 20, 2002 07:19 PM
