relocating the abs unit?
Old Oct 17, 2004 | 09:03 PM
DC2 to AP2's Avatar
Default relocating the abs unit?
ok well i just repainted my car inside and out and the engine bay looks so nice without the abs unit in there. the problem is i want abs in my car! if i was to relocate the abs pump to the trunk area using stainless steal lines or custom hardlines, would it still function the same?
im looking for a itr ABS unit.
Old Oct 17, 2004 | 09:15 PM
uNF$@#!'s Avatar
Default Re: relocating the abs unit? (xdriver)
*puts flame retardant suit on for xdriver*
Old Oct 17, 2004 | 09:19 PM
DC2 to AP2's Avatar
Default Re: relocating the abs unit? (Darkness...)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darkness... &raquo;</TD></TR><TR><TD CLASS="quote">*puts flame retardant suit on for xdriver*</TD></TR></TABLE>
thanks darkness! i know i need it for this one! it was only a thought though.
Modified by xdriver at 10:29 PM 10/17/2004
Old Oct 17, 2004 | 09:31 PM
manekDC2.'s Avatar
yea i have been wondeirng the same thing.. also do you know if the 98-01 ABS pumps are compatiable with the 94-97 ABS comp??? if they are not, are the comps. swap and play or do you have to tinker with the wiring harness to re-wire??
reasoni want to know this is, b/c the 98-01 ABS pumps are much smaller in size and lighter and i have one sitting here... my car is a 97 so i was wondering about compat. problems with my 97 ABS comp with a 98-01 ABS pump..
Old Oct 17, 2004 | 09:32 PM
manekDC2.'s Avatar
Default Re: relocating the abs unit? (manikgsr)
also is the ITR ABS unit diff then the GSR ABS unit? (pump)
Old Oct 17, 2004 | 09:41 PM
DC2 to AP2's Avatar
it should be a direct swap! the itr abs unit is different from the gsr. from what ive read and researched, the itr abs unit is better.
Old Oct 19, 2004 | 01:11 AM
manekDC2.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xdriver &raquo;</TD></TR><TR><TD CLASS="quote">it should be a direct swap! the itr abs unit is different from the gsr. from what ive read and researched, the itr abs unit is better.</TD></TR></TABLE>
is the comp. itself better or is the ITR pump better then the 98+ gs-r?? or both??
rdeezy78
Apr 16, 2007 03:40 PM
jdm_SirG
Jan 21, 2006 09:12 PM
egb18c5
Dec 19, 2005 06:25 PM
Tommy_Gunns
May 20, 2003 11:18 AM
NonovUrbizniz
Apr 15, 2003 09:12 AM
