D16z6
Old Oct 17, 2004 | 05:15 PM
oxSLEEPERxo's Avatar
Default D16z6
Can yall tell me what i need to get to have this d16z6 motor up and running? How much do yall think it will cost to get this block up and running?
-New Waterpump
-Timing Belt
-D16z6 head
-Timing Belt
-Tranny
-p28 Ecu
What hoses,wires, plugs, or etc do i need?
What am i missing that you can see that is missing off the block? Thanks
Ignore the Rice
Old Oct 17, 2004 | 06:55 PM
v4lu3s's Avatar
RTFM
looks like a pretty complete shortblock to me
probabyl jstu the head and everything attached to it...
Old Oct 17, 2004 | 07:41 PM
sleeping GIANT's Avatar
Default Re: (v4lu3s)
go ahead and save yourself some time and put a oil take-off fitting on the oil press. sensor so when you do turbo it you wont have to spend 2hours trying to put it on......j/k
-new clutch
-arp head studs(90 bucks)
-y8 head gasket(40 bucks)
Old Oct 17, 2004 | 07:54 PM
Default Re: (sleeping GIANT)
what parts can i use from my dx motor(d15b7 i think) on the d16z6 motor? what hoses do i need or wirings?
Old Oct 17, 2004 | 08:01 PM
Default Re: (oxSLEEPERxo)
can i use my 94 civic dx motor stuff for
-alternator
-starter
-ac compressorer
Stuff i need:
-Spark plugs wires
-What is that black long tube? I probably need to replace that
What else do i need? Thanks
Old Oct 18, 2004 | 09:47 AM
bump
Old Oct 23, 2004 | 10:09 PM
W.O.P.'s Avatar
why the hell do you have rice in your cylinder?
Old Oct 23, 2004 | 10:21 PM
mmuller's Avatar
Mad Scientist
Default Re: (1quickLS)
since your there i would also at leastcheck/replace the bearings, cheap insurance
Old Oct 24, 2004 | 05:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1quickLS &raquo;</TD></TR><TR><TD CLASS="quote">why the hell do you have rice in your cylinder? </TD></TR></TABLE>
I guess my motor is "RICED OUT"....hahaha...bad joke. ...Had the motor next to the rice bin, so I guess some rice spilled over into the motor. That's the only explanation i can think of.
it would be nasty if that wasn't rice but maggots. NASTY
Old Oct 24, 2004 | 11:46 AM
yes you can use alot of stuff from the b7 alt, a/c , I did on mine, !
Old Oct 29, 2004 | 05:37 PM
main bearings (D16Z6) (new oem rod & crank bearings)
thrust washers (D16Z6)
Front and Main seal (D16z6)
Oil Pump (D16Z6)
Water pump and Timing belt
ARP head bolts
Is that everything i need to rebuild the motor? How much am i expecting to spend? Do anyone have like an idea on the prices? Honda doesn't open tomorrow, so i can't call and ask for prices
dr_latino999
19
Aug 10, 2008 04:14 PM
pinoy369
Apr 24, 2007 06:00 AM
ssl2k
Feb 24, 2005 11:16 AM
oxSLEEPERxo
Oct 29, 2004 05:38 PM
