To all the SOHC soldiers
Old Oct 17, 2004 | 04:27 PM
Civic TSI's Avatar
Default To all the SOHC soldiers
Especially for the D series. Here's a little retrospective vid of my car. 56K beware, it's 60M in size.
http://www.civictsi.com/CivicTSI_Hi.mpg
Hope that you enjoy it.
Old Oct 17, 2004 | 04:32 PM
ATS*Mark's Avatar
OG triple OG
Default Re: To all the SOHC soldiers (Civic TSI)
give us a mods list.... im on 56k ill peep it tomorow when im on dsl
Old Oct 17, 2004 | 04:36 PM
Bailhatch's Avatar
very nice. don't forget to rev that thing up
Old Oct 17, 2004 | 04:38 PM
TurbodCX's Avatar
looks good bro, keep it up!!
Brian
Old Oct 17, 2004 | 05:35 PM
RA166E's Avatar
Right On!!!!
Old Oct 17, 2004 | 05:57 PM
USDM 4G VTEC's Avatar
pretty badass
good work
let me guess this is either on Europe or australia
since u got a KMPH cluster
Old Oct 17, 2004 | 05:59 PM
djwest24's Avatar
Default Re: To all the SOHC soldiers (RA166E)
Very Nice
Specs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">pretty badass
good work
since u got a KMPH cluster</TD></TR></TABLE>
im guessing, canada
Old Oct 17, 2004 | 06:00 PM
oxSLEEPERxo's Avatar
Default Re: To all the SOHC soldiers (quicksilver17981)
nice quarter mile times
Old Oct 17, 2004 | 06:19 PM
si_hatch's Avatar
Default Re: To all the SOHC soldiers (oxSLEEPERxo)
very nice video Whats your setup?
Old Oct 17, 2004 | 06:21 PM
MiKeAhOwSkI's Avatar
Default Re: To all the SOHC soldiers (si_hatch)
Lovin' it man! Good power and great times!!
Old Oct 17, 2004 | 06:27 PM
Civic TSI's Avatar
Default Re: To all the SOHC soldiers (MiKeAhOwSkI)
Canada it is.
Setup:
D16Z6 block
Ported head + custom camshaft
Custom intake manifold
Mitsu 20G turbo
3" downpipe + exhaust
I have it in complete detail in a text file at work.
Old Oct 17, 2004 | 06:57 PM
beerbongskickass's Avatar
Nice times! Good luck on going for 10's.
What tires were you running?
Old Oct 17, 2004 | 07:32 PM
BME1986's Avatar
Default Re: To all the SOHC soldiers (beerbongskickass)
Awesome car. No internals? How long you been running this setup? Are you still running an internal wastegate on the 20g? I am looknig to upgrade to a evo3 16g or 18g after I rebuild over the winter.
Old Oct 17, 2004 | 07:33 PM
The Meat's Avatar
Great times!! Love the in car shot showing the speedo/tach.
Old Oct 17, 2004 | 07:35 PM
Default Re: To all the SOHC soldiers (BME1986)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BME1986 &raquo;</TD></TR><TR><TD CLASS="quote">No internals?</TD></TR></TABLE>
I am guessing it has forged rods/pistons considering it made over 300whp on the dyno.
Old Oct 17, 2004 | 07:49 PM
boosted eg's Avatar
truely ******* awsome much respect to you
Old Oct 17, 2004 | 07:56 PM
EJ1 wilcox's Avatar
Default Re: To all the SOHC soldiers (boosted eg)
Those are some great times!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">I am guessing it has forged rods/pistons considering it made over 300whp on the dyno.</TD></TR></TABLE>
I was thinking the same thing...
Can you give any specs as to the extent of the build?
Old Oct 17, 2004 | 09:54 PM
rextec's Avatar
what kind of lag do you get on this setup?
Old Oct 18, 2004 | 05:28 AM
Civic TSI's Avatar
Default Re: (rextec)
Lag is relative to the gear. I can have 15psi at redline in 1st and I can also have 15psi @ 4000rpm in 5th.
Also, in some sequence (if not all), I'm making well over 310whp as I'm not only pushing 15psi.
Here's the complete setup
Block:
D16Z6
Stock sleeves bored .020 over
NewformZ blockguard
ARP head studs
Arias 9:1 pistons
Eagle rods
Stock crank
Head:
Ported stage 3 D16Z6 head
Manley stainless steel valves
Zex valves springs
Stock valves retainers
Custom camshaft
Skunk2 cam gear
Stock head gasket
Precision 680cc injectors
Electronics:
MSD 6AL
MSD Blaster 2 coil
MSD 2 step rev limiter
Greddy turbo timer
Greddy Profec B boost controller
Chipped ECU with Uberdata
3 bar GM map sensor
FJO wideband with gauge display
Autometer gauges
Induction:
TD05-20G (660 cfm)
FMIC 30x11x3.5
HKS SSBOV
Tial 38mm with 15psi spring external WG
Exhaust:
Custom turbo manifold
3" stainless steel downpipe
3" stainless steel exhaust
3" stainless steel Vibrant muffler
Driveline:
Protane total kit bushings
Protane motor mounts kit
Koni yellow shocks
H&R race springs
JimFab traction bars
11lbs flywheel
ClutchMaster stage 4 clutch
92 Si tranny with 4th and 5th gears from a 91 Si tranny
Quaife LSD
Stock axles
M&H 22 x 8 x 15 slicks
Toyo RA-1 street tires
Car weight about 2350lbs with me in racing form.
I should have 24.5 x 8.5 x 15 slicks for next year.
Old Oct 18, 2004 | 05:37 AM
ELSpool's Avatar
Nice vid Steph! Is that Fred in the black teg?
Modified by ELSpool at 6:06 PM 10/18/2004
Old Oct 18, 2004 | 05:59 AM
yellowturbo's Avatar
sweet we all know your secrets now loll jk !
What type of cam did you have ?? JG I think ??
Old Oct 18, 2004 | 06:07 AM
sweet video now I cant wait to see it with my speakers on loll
Old Oct 18, 2004 | 08:09 AM
gitwidit's Avatar
Default Re: (yellowturbo)
Excellent video, love your car and setup
Old Oct 18, 2004 | 08:16 AM
Civicman86's Avatar
Default Re: (GITWIDIT)
that is bad ***. Major props helping get respect to the SOHC world Hopefully I can one day get my d16 to get some respect.
Old Oct 18, 2004 | 08:26 AM
RyanEJ8's Avatar
Nice vid, I love the part where you bury the speedo doing a burnout.
