QUICK!!! How much boost will I make on my JRSC!!
I tried to do a search, but couldn't find any info on this...
I'm running a B16A head/ GS-R tranny... MVM pulley and a stock pulley on the JRSC... currently, I have it hooked up to an LS crank pulley, hoping that it'll get the boost level i'm trying to get (10PSI)...
so what PSI will I be making with this setup? will it be around 10PSI?
I also have the GS-R crank and a B16A crank I can use, if it'll make more boost...help guys!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheSwift1 »</TD></TR><TR><TD CLASS="quote">really?? how much boost do u think i'll be making?</TD></TR></TABLE>
That's not right. I don't think he noticed your mention of the MVM pulley.
Actually, to me it sounds like more than 10psi. It will be easier to figure out if you know the diameter of the LS pulley. But keep in mind that boost is relative to the rest of your setup; if you have an upgraded intake/exhaust or any kind of port work your boost is going to drop.
hypa
Feb 28, 2004 09:56 PM
