What parts for LS brakes on 93 Si w/o ABS?
Old Oct 17, 2004 | 03:30 PM
Chris93Si's Avatar
Default What parts for LS brakes on 93 Si w/o ABS?
Just wondering what I need to fit 95 LS rotors and calipers, front and rear, on my 93 Civic Si w/o ABS. Do I need the knuckles, or anything else, from the LS? Any help would be much appreciated?
TIA
Old Oct 17, 2004 | 03:38 PM
Targa250R's Avatar
be professional
Default Re: What parts for LS brakes on 93 Si w/o ABS? (Chris93Si)
You already have discs in the rear, so there is no point in swapping the rears.
In the front, you will need the entire knuckle.
I would suggest swapping the Integra brake booster and master cylinder as well. Using the larger Integra calipers with the stock Si 13/16" master cylinder will result in rediculously long pedal travel.
Old Oct 17, 2004 | 07:34 PM
Chris93Si's Avatar
Default Re: What parts for LS brakes on 93 Si w/o ABS? (Targa250R)
Thanks for the info, what's needed for the rears?
Old Oct 17, 2004 | 07:35 PM
Targa250R's Avatar
be professional
'92-95 Civic Si rear discs and calipers are identical to '94-01 Integra rears. There is no point in swapping them because they are the same.
This may help: https://honda-tech.com/zerothread?id=152884
tangerinebeast
Jul 22, 2011 10:16 AM
92si_XX
Jun 25, 2011 08:01 AM
tortora
Mar 6, 2011 02:04 PM
95civic_ls_vtec
Jun 16, 2010 02:13 PM
blac00si
Jun 23, 2005 06:56 PM
