Gettin CEL after map install. wiring help needed.
OK i installed my Map sensor like i was suppose to. My new harness i bought did not have a MAP on it so i used a TPS harness and plug since it was the same as the MAP sensor.
I wired
#1 to slot D19 on the ECU
#2 to Slot D21 on the ECU
#3 to slot D17 on the ECU.
Im pretty sure these are correct but Its still throwing a code for the map sensor
The car is bogging Horribly. The Map sensor was good b4 i changed out the clutch and i havent touched it at all since ive had the car.
I wired
