What to do about TDC Position CEL#8
Old Oct 17, 2004 | 01:35 PM
beseman's Avatar
Default What to do about TDC Position CEL#8
Since the search function is down now,
i came back to my car last night and it didnt start, so i popped the clutch and the whole way home and since i have been getting a tdc position sensor code.
what do i need to look for in the distributor to find what has gone ba??
1 more thing, i have a external kill switch and my girlfriends sisters husband was palying with it when i wasnt there, could that have shorted it out or something?
Old Oct 17, 2004 | 03:17 PM
smart monkey's Avatar
Default Re: What to do about TDC Position CEL#8 (beseman)
either dist went bad also double check the cam timing just to be sure
Old Oct 17, 2004 | 03:45 PM
beseman's Avatar
Default Re: What to do about TDC Position CEL#8 (smart monkey)
so what inside the dist should be replaced, the cap?
Old Oct 17, 2004 | 03:47 PM
no not the cap. the tdc sensor is in the dist. if it is bad you would either have to change dists or that part but now since whole dists are cheap you could just get a whole dist
Old Oct 17, 2004 | 04:20 PM
beseman's Avatar
where do you get a cheap dizzy?
i havent seen any
Old Oct 17, 2004 | 04:26 PM
Nic's Avatar
Nic
there is a website
try google I forgot the name of it
Old Oct 17, 2004 | 04:27 PM
Default Re: (stk crx)
try to post a WTB classified or see if a local HTer to you has one so you can use to test to be sure. also check distking.
Old Oct 18, 2004 | 03:38 PM
beseman's Avatar
ok this is cool
the check engine light is gone, but when i pull back the carpet the ecu is still throwing the code????
Old Oct 18, 2004 | 04:59 PM
that mean the problem is not gone. everytime you turn off the car and turn on the light on the dash will go away but the ecu will store the code until it is fixed and the ecu is reset.
Derrick_12341
Jul 26, 2018 07:15 AM
M3THTICAL(EF)
Jul 24, 2016 08:24 AM
BoostedH23a1
Apr 18, 2005 03:19 PM
hybridEj6
Sep 11, 2003 06:41 PM
