Crank key...
Old Oct 17, 2004 | 12:12 PM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Crank key...
Where can I find a crank pulley key for an 88 d16a6? any help would just kick ***...
Old Oct 17, 2004 | 12:41 PM
AgentJam's Avatar
Default Re: Crank key... (h8tred)
Honda dealer or junkyard...or someone who has one laying around??? Doubt that because usually a key stays with the block.
h8tred's Avatar
I tried Autozon, Advance, and Napa, but Napa didn't answer. They can't even get the pulley...
Thanks AgentJam, I had a junk block, but I tossed it. I think I'll try to make one...
Old Oct 17, 2004 | 12:53 PM
Super79Dave's Avatar
Just order one from the honda dealer there like $2.00ea. usually in stock.
Don't try making one unless you have for a template if it's too short or too long it won't stay there. Also it's made of hardened material so if you make one it should be the same.
Old Oct 17, 2004 | 01:00 PM
carnifex's Avatar
Default Re: Crank key... (Super79Dave)
i got mine at the local home depot. they are called a "woodruff key" they had about a hundred different sizes.
Old Oct 17, 2004 | 01:39 PM
h8tred's Avatar
Default Re: Crank key... (carnifex)
I made one out of a paint can opener. I forged it with a hammer to get the same shape as the old one. I think I'll still get the OEM one though. They're closed today though and I need to go 150 miles to work tomorrow night.
So this is my only option.
Old Oct 17, 2004 | 05:02 PM
AgentJam's Avatar
dude...if you could hammer it into a shape then don't use it. I wouldn't risk it honestly. I guess if it survives startup then it should be okay as long as you don't rev or drop rpms quickly
Vince
Old Oct 17, 2004 | 05:12 PM
h8tred's Avatar
Default Re: Crank key... (AgentJam)
It's not real soft, but it's not as hard as the og one. I've been running around getting the rest of the things I need to tune up the engine, and it hasn't slipped or anything. I think it'll last until I can get something better. Thanks for the concern though.
Old Oct 17, 2004 | 05:13 PM
mr. carpenter's Avatar
i think you can get one at a honda dealer parts dept.?
Old Oct 17, 2004 | 07:47 PM
h8tred's Avatar
Default Re: Crank key... (mr. carpenter)
That's my best guess, because no parts stores can get the pulley, much less the key. I'll look at home depot, I know for sure if I can get one at honda, I will. I have to get a dizzy seal too while I'm there. This thread is done... If you have this problem, get a few as to have extras. For dumbasses like me to bum off you. Ha
If anyone is interested, I'll get part numbers and such.
Old Oct 17, 2004 | 07:48 PM
deftones0817's Avatar
you can get the key fron honda i just bought one like 2 days ago. They usually have that part in stock too.
DEF
Old Oct 17, 2004 | 08:01 PM
4drEF's Avatar
Keyboard Humorist
You can make your own woodruff key out of just about anything. I used some aluminum rod and filed it down until it fit into the crank with a tap of a hammer. It lasted over 3 years and a few timing belt changes.
Old Oct 18, 2004 | 09:24 AM
h8tred's Avatar
Default Re: Crank key... (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">You can make your own woodruff key out of just about anything. I used some aluminum rod and filed it down until it fit into the crank with a tap of a hammer. It lasted over 3 years and a few timing belt changes.</TD></TR></TABLE>
My temporary is made of some sort of alloy, but I'm not going to jeperdize my engine. I called Honda today and they have 5 in stock. I'll go ahead and get the part numbers. Thanks everyone for the replys and ideas.
Old Oct 18, 2004 | 11:11 AM
h8tred's Avatar
Honda part # (90704-634-000) $2.75.
zurud
12
Feb 27, 2010 06:49 AM
oranginal
Jul 3, 2009 02:20 PM
slor209
Mar 12, 2008 01:02 PM
JDM00SI
Dec 29, 2005 09:42 AM
__37__
Jun 19, 2003 09:26 PM
