bigger oil pump?
Old Oct 17, 2004 | 11:24 AM
crazyslowhatch's Avatar
Default bigger oil pump?
is the d16 oil pump bigger then the d15 oil pump? and how hard is it to change the oil pump?
Old Oct 17, 2004 | 11:31 AM
ef8 h0!'s Avatar
Default Re: bigger oil pump? (crazyslowhatch)
why are u going to be boosting? if not it's kinda pointless?????
Old Oct 17, 2004 | 12:13 PM
AgentJam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyslowhatch &raquo;</TD></TR><TR><TD CLASS="quote"> is the d16 oil pump bigger then the d15 oil pump? and how hard is it to change the oil pump?</TD></TR></TABLE>
I'm pretty sure d15 pumps will bolt up the same as d16 but keep in mind each pump from engine to engine will have different psi ratings. I know the d16z6 pump puts out more than d16y8 and d16a6...correct me if i'm wrong people.
It's a time consuming job but this is what it involves...
Drain oil
Remove crank pulley/timing belt cover
Remove timing belt
Remove oil pan
Remove oil pickup tube
Remove oil pump
Reinstall everything.
I could have missed something i removed/replaced pump with block out of car so correct me someone if i missed something.
Vince
Old Oct 17, 2004 | 10:04 PM
Default Re: bigger oil pump? (AgentJam)
thanks, well i have a d15b that i put a y8 head on, and i'm tryin to get together a turbo kit so i thought i might put a d16 pump in it if its any bigger..? would it be worth it?
Modified by crazyslowhatch at 5:41 PM 10/18/2004
allmotor_guys
Jul 11, 2009 07:05 PM
Mefain
May 16, 2003 09:02 AM
echo999
Apr 26, 2003 08:58 AM
