d16z6 into a first gen crx?
if your looking for a crx, it should be 88 and up since its easier to swap in thos engines
, if you do buy a 87 and below crx, get ready to custom make mounts and stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control »</TD></TR><TR><TD CLASS="quote">if your looking for a crx, it should be 88 and up since its easier to swap in thos engines
, if you do buy a 87 and below crx, get ready to custom make mounts and stuff.</TD></TR></TABLE>
no true hasport has them for the 84-87
then you just have to find a si wiring harness and sub harness. thats for the b series
Screw you guys, I'm... going... home.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bernie’sb16crx »</TD></TR><TR><TD CLASS="quote">no true hasport has them for the 84-87
then you just have to find a si wiring harness and sub harness. thats for the b series</TD></TR></TABLE>
They only have them for putting a B-series into an 84-87 1g rex. He wants to put a D16Z6 into one.
then you just have to find a si wiring harness and sub harness. thats for the b series</TD></TR></TABLE>They only have them for putting a B-series into an 84-87 1g rex. He wants to put a D16Z6 into one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smart monkey »</TD></TR><TR><TD CLASS="quote">i looked into doing this swap once. it is not even bolt in. lots of work to do. you are better off doing a zc or a b16a swap. </TD></TR></TABLE> The only engines that are *bolt in* are a D16A1 out of a 86-89 usdm integra or a jdm browntop zc or an *early* jdm blacktop zc (NOT the later blacktop zc for 88+ civics/crxs).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm »</TD></TR><TR><TD CLASS="quote">lthey do have an electric fuel pump, even on the carb'd ones.</TD></TR></TABLE> Um, no. All usdm Sis had electric fuel pumps, all carbed models had the fuel pump run off an eccentric on the camshaft.
