zc tranny on z6
Old Oct 17, 2004 | 09:29 AM
whiteknightef's Avatar
Default zc tranny on z6
how easy does an lsd zc tranny fit up to a d16z6 in a 1990 civic si. what kind of problems am i going to see and what things do i need to do?
Old Oct 17, 2004 | 09:30 AM
4drEF's Avatar
Keyboard Humorist
Default Re: zc tranny on z6 (trigger69)
Direct bolt on.
Old Oct 17, 2004 | 09:32 AM
2point2's Avatar
Default Re: zc tranny on z6 (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">Direct bolt on.</TD></TR></TABLE>
What about axles? the zc tranny uses teg inners..
Old Oct 17, 2004 | 09:55 AM
Default Re: zc tranny on z6 (2point2)
ya i need to know everthing before i buy it
Old Oct 17, 2004 | 12:08 PM
Sobe_Death's Avatar
you will have to use the zc intermediate shaft, and the holes for the shaft bracket will need to be tapped unless they are already threaded.
Old Oct 17, 2004 | 02:58 PM
Default Re: zc tranny on z6 (Sobe_Death)
what holes?
Old Oct 17, 2004 | 03:14 PM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trigger69 &raquo;</TD></TR><TR><TD CLASS="quote">what holes?
The ones on the back of the block that the intermediate shaft mounts to.
Old Oct 17, 2004 | 11:01 PM
Default Re: zc tranny on z6 (CRXBart)
ok so everthing else will bolt up then. Does anyone know if my act clutch from my si tranny will bolt up too?
Old Oct 18, 2004 | 03:27 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trigger69 &raquo;</TD></TR><TR><TD CLASS="quote">ok so everthing else will bolt up then. Does anyone know if my act clutch from my si tranny will bolt up too?</TD></TR></TABLE>
depends on the year.. is it an 88?
Old Oct 18, 2004 | 10:55 PM
the tranny i am using right now is a 90 si that was in the car with a z6 motor. i want the lsd on the zc so i was wondering whats needed?
Old Oct 19, 2004 | 06:14 PM
underage's Avatar
i don't think it will work. i tried this with a d16y7 and the engine didn't have any bolt holes built out far enough on the block. in other words, the intermediate shaft had nothing to bolt to, no holes that could have been tapped, and it didn't have any metal on the back of the block that could have supported it.
Old Oct 20, 2004 | 10:58 PM
Default Re: zc tranny on z6 (underage)
well im good with medal so i could build a bracket and also the z6 has a huge dead space that is really thick right there i think if i remember tight from the installation.
Old Oct 20, 2004 | 10:59 PM
anyone ahve any other suggestions? what about putting the zc lsd differencial into the si tranny
Old Oct 21, 2004 | 01:45 AM
SEA Hag's Avatar
D16a6 from 4wd wagovans have intermediate shafts. look into that
Old Oct 21, 2004 | 07:00 AM
2point2's Avatar
read the sig
Old Oct 21, 2004 | 07:03 AM
mrspeaker's Avatar
Default Re: (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">read the sig </TD></TR></TABLE>
LOL Perfect timing..
trooper0641
10
Feb 6, 2005 05:20 PM
trooper0641
Oct 29, 2004 07:13 PM
sloweredcivic
Oct 1, 2003 11:58 AM
VELOCITY R
Sep 4, 2003 05:37 AM
Toptul_Honda
Apr 22, 2003 12:13 PM
