Wheel question...
Old Oct 17, 2004 | 06:36 AM
prayludin's Avatar
Default Wheel question...
Will Konig Rated R's fit on my 97 prelude? I need to know because I need a winter wheel and I can get a set very cheap. Thanks in advance.
Old Oct 17, 2004 | 11:43 AM
UA6 BALLER STATUS's Avatar
Default Re: Wheel question... (prayludin)
We need more info about the wheel to answer this question. what size and width is the wheel and tires?
Old Oct 17, 2004 | 11:53 AM
prayludin's Avatar
Default Re: Wheel question... (Type SH)
I mean does the rim fit on at all. like will the holes for the lugs line up?
Old Oct 17, 2004 | 12:21 PM
britishlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prayludin &raquo;</TD></TR><TR><TD CLASS="quote">I mean does the rim fit on at all. like will the holes for the lugs line up?</TD></TR></TABLE>
According to this site Konig R wheels will fit the Lude, but you HAVE to get the 5 stud 114.3 mm PCD for the wheel to fit 5th gen studs, these come with 40mm offset which will be fine.
http://www.wheelspecs.com/specs/wheelmodels/205
Are you planning on 15", stock 16" or upsizing to 17" ? Because they are available in all the diameters.
Old Oct 17, 2004 | 12:23 PM
georgiajdm's Avatar
dude your a flipping idiot
Old Oct 17, 2004 | 07:48 PM
prayludin's Avatar
so a 17 inch rated r will or will not fit?
Old Oct 17, 2004 | 07:52 PM
bad-monkey's Avatar
Default Re: (georgiajdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgiajdm &raquo;</TD></TR><TR><TD CLASS="quote">dude your a flipping idiot</TD></TR></TABLE>
you'RE
Old Oct 17, 2004 | 07:53 PM
bad-monkey's Avatar
Default Re: (prayludin)
depends on what tires you're running.
40 offset isn't enough imo. you'll rub.
Old Oct 18, 2004 | 01:34 AM
Default Re: (bad-monkey)
If you want a set of cheap steel 15" wheels for winter use that you can be certain will fit, get some steelies off a Honda CR-V they fit for sure and won't be much dearer if at all.
::MUGEN::INTEGRA::RSi
Apr 7, 2006 04:14 AM
BB6Paul
Dec 6, 2005 12:14 PM
JDM SLICK
May 31, 2005 11:49 AM
.::miLan
May 16, 2005 04:30 AM
