shaking steering wheel when i brake?
Old Oct 17, 2004 | 04:07 AM
E36 Guy's Avatar
Default shaking steering wheel when i brake?
Usually at high speeds (freeway) when I break, I can fell the steering wheel and brake pedal shake. Anyone know what is causing this?
Old Oct 17, 2004 | 04:30 AM
hayabusa160's Avatar
Default Re: shaking steering wheel when i brake? (b18c3)
that would usually be warped rotors. or other things in the driveline axles, maybe you need an alignment.
if you have slotted rotors it will also do that also. i rember when i had slotted rotors you can feel the brake petal vibrate
Old Oct 17, 2004 | 05:03 AM
93CivicSI's Avatar
Read this about 'warped' brake rotors...
http://www.stoptech.com/whitep...h.htm
Old Oct 17, 2004 | 06:09 AM
accident prone's Avatar
i agree with all above and have another set of solutions, 1 would be tires, i had low shitty tires and the vibrated when i tried to brake alos if i braked harder they slid that was so fun, 2nd is bent rims one of my steelis was bent from a curb from the owner before me and when i braked that side vibrated and it made the steering wheel, otherwise an alignment rotors, slotted brakes, it could be alot of things
sagacious
14
Jul 29, 2012 08:56 AM
arielb1
May 23, 2009 09:09 AM
james p.
13
Jun 5, 2005 08:17 AM
civinprogress
Jul 11, 2004 09:23 AM
RacerXintegra2k
Sep 25, 2002 05:03 PM
