In dying need of more torque!
Old Oct 17, 2004 | 01:15 AM
Takashi1978's Avatar
Default In dying need of more torque!
Hi guys,
I have a B16B EK. From my readings this engine is basically a de-stroked B18C right?
Would just buying a 1.8L crankshaft and putting it in the existing block increase my displacement?
Any mods i need to do to the block to achieve this?
Or is it less hassle and cheaper to bolt up a B18C block?
1.8L crank i havent find out how much it cost but a JDM ITR block cost about USD700 here in Malaysia.
Thanks for all the help in advance guys!
Old Oct 17, 2004 | 03:56 AM
RagingAngel's Avatar
Default Re: In dying need of more torque! (Takashi1978)
you need the crank and the rods bare minimum to give you 1.8L
stock pistons can stay, but they will up your compression a couple of points from 10.8:1 on the 16B
Old Oct 17, 2004 | 04:07 AM
Default Re: In dying need of more torque! (RagingAngel)
Can you explain more on how the rods come into play?
Old Oct 17, 2004 | 09:35 AM
Kyle244R948's Avatar
b16 blocks have smaller rods then b18 blocks
Old Oct 17, 2004 | 09:42 AM
Bbasso's Avatar
How much torque do you really think your going to get from increasing the displacement 0.2 ?
Time to get a Mustang
Old Oct 17, 2004 | 09:44 AM
ITR 2K's Avatar
If you want torque, then you shouldn't have bought a Honda.
Old Oct 17, 2004 | 10:43 AM
ZygSpeed's Avatar
... turbo!
Even with only 5-7 psi of boost on the stock motor, you'll make a tremendous difference and increase your torque by ~ 50%
Old Oct 17, 2004 | 10:46 AM
Type-Rare#1248's Avatar
Default Re: In dying need of more torque! (zygspeed)
a lightened flywheel make you feel like you have a lot more torque...i know cuz i got one in my car
Old Oct 17, 2004 | 12:53 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">... turbo!
Even with only 5-7 psi of boost on the stock motor, you'll make a tremendous difference and increase your torque by ~ 50%</TD></TR></TABLE>
I gotz 100% more torque with 10 PSI.
TURBO!
(see torquey dyno in link in sig)
Old Oct 18, 2004 | 05:58 PM
IntegraTionR's Avatar
Default Re: In dying need of more torque! (ccfries)
I wonder how to get 100% more torque? Would that equate to 200%?
Old Oct 18, 2004 | 06:07 PM
Chris F's Avatar
Default Re: In dying need of more torque! (IntegraTionR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraTionR &raquo;</TD></TR><TR><TD CLASS="quote">I wonder how to get 100% more torque? Would that equate to 200%? </TD></TR></TABLE>
Yes. 200% of 110 ft-lb == 220 ft-lb.
jdmH2Bek4
Dec 22, 2012 01:14 PM
Wytek9
Apr 23, 2008 09:32 AM
jcivic33
Feb 12, 2005 07:19 PM
buckNasty
15
Jan 15, 2004 05:42 PM
topsekret
Aug 5, 2003 08:33 PM
