Help with my 89 civic
Old Oct 16, 2004 | 11:40 PM
Dee888's Avatar
Default Help with my 89 civic
I had the water pump go bad recently on my 89 civic, I bought one from a local junk yard and installed it. As soon as i started it up it ran like **** and died , it would start back up but still run like ****. The day before i installed the water pump i did a tune up on it. Someone told me i may have moved something while installing the water pump so when i started it i bent a valve I dont know if this is true and i really dont want to go thru taking my head about and crap to fine out that it anit bent. Maybe the timing is off? maybe the distributor went bad? i really dont know maybe someone here can be kind and help me out with it thanks a lot!
Old Oct 17, 2004 | 12:33 AM
ef8 h0!'s Avatar
Default Re: Help with my 89 civic (Dee888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee888 &raquo;</TD></TR><TR><TD CLASS="quote">I had the water pump go bad recently on my 89 civic, I bought one from a local junk yard and installed it. As soon as i started it up it ran like **** and died , it would start back up but still run like ****. The day before i installed the water pump i did a tune up on it. Someone told me i may have moved something while installing the water pump so when i started it i bent a valve I dont know if this is true and i really dont want to go thru taking my head about and crap to fine out that it anit bent. Maybe the timing is off? maybe the distributor went bad? i really dont know maybe someone here can be kind and help me out with it thanks a lot!</TD></TR></TABLE>
wow, why the hell did you buy a used water pump for? and did you put everything at top dead center before you put the belt back on? if you didnt you probly bent a valve and now the head needs to be built.
kitteekate
Apr 13, 2008 12:47 PM
rohec04
Oct 27, 2007 05:56 PM
918-Hatch
Aug 8, 2007 04:15 PM
mizzoEG
Jul 21, 2007 06:00 PM
