Bosch Platnium +4 ok to use instead of Zex plugs?
Old Dec 17, 2001 | 02:11 PM
Duck Sauce's Avatar
Default Bosch Platnium +4 ok to use instead of Zex plugs?
Can you use Bosch +4's instead of Zex "Hyperformance" plugs when using Nitrous?
Old Dec 17, 2001 | 02:14 PM
Spade's Avatar
Default Re: Bosch Platnium +4 ok to use instead of Zex plugs? (www.s4-mtm.com)
the +4's aren't worth it just get the NGK's.....they don't burn as hot.
Old Dec 17, 2001 | 08:09 PM
Mike K's Avatar
Default Re: Bosch Platnium +4 ok to use instead of Zex plugs? (Spade)
Bosch +4 and ZEX both suck.
Depending on your jet size, I'd say a BKR8E-11 would be good (Honda part # is 98079-5814E)
Old Dec 17, 2001 | 10:53 PM
Mista Bone's Avatar
D Tranny Guru
Bosch 4227, 2 steps colder, $1.99 each.
Old Dec 17, 2001 | 11:20 PM
Duck Sauce's Avatar
Default Re: Bosch Platnium +4 ok to use instead of Zex plugs? (Mista Bone)
Can you explain why Bosch Platinum +4's suck? I also have some NGK Platinums. Ignition system consists of a MSD 6AL, Blaster SS coil and MSD 8.5mm wires.
Old Dec 18, 2001 | 09:01 AM
Mista Bone's Avatar
D Tranny Guru
Plat's have a weaker spark, but last forever.
BTW Where did I say they sucked?
Old Dec 18, 2001 | 10:36 AM
FAST4DR's Avatar
True, true. Plat is a much weaker conductor than conventional copper. The advantage to plats is their longevity. I prefer to use the non-plat NGK and change them when needed.
Old Dec 18, 2001 | 12:03 PM
Crazy DA's Avatar
New User
Default Re: Bosch Platnium +4 ok to use instead of Zex plugs? (FAST4DR)
whats the diff between the BKR7E-11 versus the BCPR7E-11??
Old Dec 18, 2001 | 04:58 PM
97accordex's Avatar
Default Re: Bosch Platnium +4 ok to use instead of Zex plugs? (Crazy DA)
Check out the NGK website. They have a pdf that shows how their part number is constructed and how to select cooler/hotter plugs.
BKR7E-11 breaks out like this,,,,,,
B is a 14 mm thread diam
K is a 5/8" hex plug with projected tip
R R is a resistive (duh) plug
7 is the heat range; Stock is 6 on my accord. I have been running 5's
E is thread reach,,,, 19 mm (3/4") for E
11 is gap 1.1 mm or .044"
Old Dec 18, 2001 | 04:59 PM
97accordex's Avatar
Default Re: Bosch Platnium +4 ok to use instead of Zex plugs? (97accordex)
Oh,,
The CP just means that it has a projected insulator. Not sure what this buys you.
hondaeg8
Sep 26, 2004 11:46 PM
tegon-gsr
Jun 4, 2004 11:44 AM
sting94112
Apr 18, 2004 04:26 AM
kwik92hb
Nov 17, 2003 08:56 AM
Duck Sauce
Jan 13, 2002 06:17 PM
