88-89 tranny 90-91 tranny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs »</TD></TR><TR><TD CLASS="quote">no not all are alike ... the only difference in a SI tranny are the 88 model... i think it has 21 splines... rather than the 89-90 20 splines...</TD></TR></TABLE>
close, it's 21 splines on the '88 and only 20 on the others
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S9i1R »</TD></TR><TR><TD CLASS="quote">
close, it's 21 splines on the '88 and only 20 on the others</TD></TR></TABLE>
If you want to use a 88 tranny with a 89-91 clutch/fly, you need a 89 prelude disk (same dia as 89-91 clutch, but with the correct spline count)
It's been a long time though, can any one back me on this? I forget exactly which year prelude crosses over, ACT told me years ago...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locovirus »</TD></TR><TR><TD CLASS="quote">what are splines?</TD></TR></TABLE>
splines are the number of teeth marks on the tranny .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keith P »</TD></TR><TR><TD CLASS="quote">If you want to use a 88 tranny with a 89-91 clutch/fly, you need a 89 prelude disk (same dia as 89-91 clutch, but with the correct spline count)
It's been a long time though, can any one back me on this? I forget exactly which year prelude crosses over, ACT told me years ago...</TD></TR></TABLE>
I know the 88 Accord or 87 Prelude clutch discs work. Im not sure if the 89 Prelude is the same.
thx for correcting me... i know where the link or info i got that out from but i was just too lazy to look for it...
El Veterano de Sur Califas
good info. so it would be wise to use a 90-91 clutch disk on an 89 ?? since the disk is larger?? better upgrade if you are gonna get a new one anyway? right? I have a d series tranny and dont know what year it is, so i will gamble with a 90-91 clutch setup. Hope its not an 88...
manny
manny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mannyman »</TD></TR><TR><TD CLASS="quote">good info. so it would be wise to use a 90-91 clutch disk on an 89 ?? since the disk is larger?? better upgrade if you are gonna get a new one anyway? right? I have a d series tranny and dont know what year it is, so i will gamble with a 90-91 clutch setup. Hope its not an 88...
manny </TD></TR></TABLE>
well i got better info you can use the clutch disc and flywheel from any 92-95 civic its same size as the 91 not the 90... and its lighter...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">IIRC the 90-91 have a 35mm bearing and 88-89 have a 40 mm bearing...it makes a difference if you want to go with a LSD...</TD></TR></TABLE>
88-89 civic/crx si models and 90-91 ex 4dr's have the 40mm bearing. only the 90-91 civic/crx si models have the 35mm bearing. just wanted to let you guys know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loaded Butane »</TD></TR><TR><TD CLASS="quote">Im pretty sure you would need the 90-91 flywheel also. </TD></TR></TABLE>
is this true. doesnt seem it would matter. any confirmation??
manny
manny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peiku »</TD></TR><TR><TD CLASS="quote">88-89 civic/crx si models and 90-91 ex 4dr's have the 40mm bearing. only the 90-91 civic/crx si models have the 35mm bearing. just wanted to let you guys know.</TD></TR></TABLE>
Apparently this is actually untrue. Quaife sells LSDs labelled that way, but Mista Bone has taken a bunch apart and says that the 90-91 Sis all had the same 40mm bearing as the 88-89 and 92+.
And yes, you would need the 90+ flywheel (212mm).
well i got better info you can use the clutch disc and flywheel from any 92-95 civic its same size as the 91 not the 90... and its lighter...</TD></TR></TABLE>
i thought the 92-95 clutch disc was a little larger,
but sometimes when i think my brain hurts
Are you a ****** psychic? I was gonna post that exact question. Can you hook me up with some Louisiana lotto numbers?
bolt on with no performance lost of course
